I have a new project in which a brand new i.MX hardware board is developed, it's based on the i.MX8X evaluation board but a lot of peripherals are replaced to our needs.
My job is to verify the board's hardware is working, for example, the imx8x mcu, its ram, flash, and other drivers. I would like to check what's the very first software/firmware debug task in this case?
For an imx8x evk, its hardware is guaranteed to work, so the first step is usually to connect the usb console port, the usb port to PC, and use UUU to flash a kernel or uboot to the hardware, am I right?
This seems to be a linux based approach. Will "MCUXpresso SDK" be more helpful in my case?
For a new imx8x board in my case, can I do the same task? What if the usb console port is not even recognized in the PC?
I'm a little confused here, any common practice to do as the first step?
Thanks Fei
Solved! Go to Solution.
Hi Fei
first recommended to follow i.MX 8QuadMax/i.MX 8QuadXPlus Hardware Developer’s Guide
check power supplies, clocks, make usb working. Then run ddr test (use RPA tool)
Follow document: MX8_DDR_Tool_User_Guide.pdf included in DDR Stress Test for necessary software
changes. i.MX8 processors use SFW concept, it is described in SCFW Porting Kit
https://imxdev.gitlab.io/tutorial/System_controller_unit_introduction_for_imx_8qxp_mek/
Debugging
AN12631 Normal and Secure Debug for i.MX8/8X Family of Applications Processors
For M4 development use SDK_MEK-MIMX8QX available on https://mcuxpresso.nxp.com/en/welcome
IAR and SEGGER tool patch for i.MX 8DualXPlus and i.MX 8QuadXPlus
https://www.nxp.com/webapp/Download?colCode=SDK_MX8QX_3RDPARTY_Patch&appType=license
Hi Fei
Debugging
