What's the difference between the .dts files under linux-imx and uboot-imx?
1,627 次查看
viking_yuan
I saw, e.g. i.MX6UL, same file imx6ul-14x14-evk.dts under folders uboot-imx/arch/arm/dts and linxu-imx/arch/arm/boot/dts. Also I saw the same settings (e.g. uart2, usbotg1 and etc...) imx6ul-14x14-evk.dts in both of the above 2 folders. If I'd like to change the settings, e.g. usb1otg, which .dts should I modify? What's the reason to have same .dts files under these 2 folders?
1,617 次查看
Zhiming_Liu
If you want to use usb/uart function in bootloader stage ,change the uboot dts.
If you want to use usb/uart function in linux stage,change the kernel dts.The kernel driver get dts node from kernel dts.If you want to use uart in linux shell, you need change the kernel dts.Normally,most dts change happened in kernel dts.
Zhiming
1,618 次查看
Zhiming_Liu
Zhiming
