Hello Jinshan Chen,
You may find the Out of Reset conditions of pins on Table 96 of the i.MX6S/DL Datasheet.
http://www.nxp.com/files/32bit/doc/data_sheet/IMX6SDLCEC.pdf
Most pins have the same before and after reset values, except for the signals in table 97.
I hope this helps!
