What onboard USB controller is implemented into i.MX 8m?
1,449 次查看
contact3
What implementation you are using internally as the USB host controller on the i.MX 8M series? EX, Intel/ASmedia... version number, etc. This is not mentioned on your data sheets. Thank you very much!
标签 (1)
标记 (4)
3 回复数
1,272 次查看
Hi Ty
seems this is designware cores, as one can find its
references in sect.11.1.3.23.2 Diagram  - "DWC_*"    i.MX8MDQ Reference Manual
https://www.nxp.com/webapp/Download?colCode=IMX8MDQLQRM&Parent_nodeId=1480454149826718646460&Parent_...
1,272 次查看
contact3
Thank you muchly igor, though the link currently does not work.
1,272 次查看
