What is the purpose of the ns_bind/unbind calls in the multicore ping-pong example?
1,016 次查看
EdSutter
Senior Contributor II
Referring to the rpmsg_lite_pingpong_rtos_linux_remote multicore example, what is the purpose of the rpmsg_ns_bind()/unbind() calls?  The handle returned by the bind is not used, and I found I can comment those two lines out with no negative effect.
Ed
标签 (1)
1 回复
987 次查看
Harvey021
Hi @EdSutter
You can go through the middleware/multicore/rpmsg_lite/lib/rpmsg_lite/rpmsg_ns.c
Harvey
