I don't quite understand what you mean by local or global memory. GPU usually has some reserved memory space and this memory can be configured at boot time. Access to this memory is fast. when this memory is used up, gpu will go to system memory. The memory access speed also has something to do with the type of memory used.
DDR3L/LPDDR4 1066/1200MHz
This is based on our board. For your board, it needs to be calculated by yourself.
Diego.
