What is the maximum ambient temperature supported by i.MX8XLite?
已解决
跳至解决方案
1,359 次查看
deega_jung
Dear NXP support team,
Could you let me know what is the maximum ambient temperature supported by i.MX8XLite?
According to i.MX8XLite data sheet, it support to maximum junction temperature has 125degC but I don't check the ambient temperature.
Deega Jung
1 解答
1,314 次查看
riteshmpatel
Hi @deega_jung,
I hope you are doing well.
One can calculate the Ambient operating temperature on the basis of the junction temperature. Also, one can refer to the thermal analysis document at the below link.
https://www.nxp.com/docs/en/white-paper/BasicThermalWP.pdf
TJ = TA + (PD RQJA)
One can find the value of RQJA in the datasheet in Table 4. FCPBGA package thermal resistance data.
Thanks & Regards,
Ritesh M Patel
在原帖中查看解决方案
2 回复数
1,275 次查看
deega_jung
Hi Ritesh M Patel,
I'm sorry late response for your comment, thank you so much. I refer to your comment.
Deega
1,315 次查看
riteshmpatel
Hi @deega_jung,
TJ = TA + (PD RQJA)
Thanks & Regards,
Ritesh M Patel
