I am running on LTIB currently
- and looking at adding Qt to that
However, would you recommend moving to Yocto currently?
- i.e. is it stable enough yet?
- is it fully supported with the latest packages?
I also need gstreamer support, multi-screen support and (parallel-bus) camera support
- so need to know if Yocto is better for this also!
If I go with Yocto, does it still support the Ubuntu GUI, or similar?
(sorry, I'm not a Linux guru!)
Phil
