We're new to the i.mx world, and looking at upgrading an existing instrument design from an old Atmel ARM chip to use the i.mx6d. We need a local bus to talk to some existing FPGAs, and the EIM would work for that, but it looks like that would conflict with some of the possible video in/out capabilities which we would like to use. The software folks are excited about some of the feature this chip has, but I'm still trying to figure out, if I use feature A, I won't be able to pin out feature B. I've started using the Pin Tool, but that seems a little 'trial and error'. Is there a higher level document that covers the possible configurations and limitations?
Hi Bill
pin tool is based on i.MX6 documentation, for example for i.MX6DQ
please check i.MX6DQ Reference Manual Chapter 4
External Signals and Pin Multiplexing, Chapter 36 IOMUX Controller (IOMUXC)
http://cache.freescale.com/files/32bit/doc/ref_manual/IMX6DQRM.pdf
