What is the DCP key longevity on the i.MX6ULL?
JohnKlug
Senior Contributor I
AN12901 (which I am not sure applies to the i.MX6ULL) says:
The DCP implements four SRAM-based keys that can be used by the software to securely store keys on a semi-permanent basis.
Does the i.MX6ULL DCP key storage degrade over time when no power is applied to the CPU?  If so, what is the lifetime of a device that is not powered up?
