What is state of screen Mirroring of Qt Applications on LVDS and HDMI?
2,184 次查看
mohsen2013
hi dears,
how is it possible to mirror qt app?
i don't know which backend(x, xwayland, wayland, fbdev, drm, ...) support this feature and what build system (YOCTO and Buildroot) and which version does support this.
I tested bsp community yocto 2.4 with fbdev+eglfs , separate screen works fine but dual lvds not, and also tested in buildroot with etnaviv.later support screen mirroring  but needs two screen should have same resolutions? and it is impossible to have different resolution.
so which build system and what backend currently support screen mirroring with different resolution of displays with qt?
thanks
标签 (4)
2,020 次查看
Bio_TICFSL
Hello mohsen,
Depend of you board, the change state in DTS files as example the mx8, for HDMI and LVDS at 1080p @60fps  the file fsl-imx8.dtb for xwayland, qt and yocto.
2,020 次查看
mohsen2013
Hello
Do you support screen mirroring with different  LVDS and HDMI resolutions( for example LVDS 1368x768 and HDMI 1280x720) ?
