What is a bit18 of PMU_LOWPWR_CTRLn register?
ソリューションへジャンプ
1,477件の閲覧回数
takayuki_ishii
Contributor V
Hello community,
In B.1.51 PMU Revision History of IMX6DQRM rev.4 09/2017,
It say that "Updated the Bit 18 of PMU_LOWPWR_CTRLn to reserved."
But PMU registers of i.MX6Dual/Quad, it have no PMU_LOWPWR_CTRLn register.
What is that meaning of this history?
It seems that mistake copy&past from IMX6ULRM.
Can I trust revision history of IMX6DQRM rev.4?
Ishii.
ラベル(3)
1,347件の閲覧回数
Bio_TICFSL
Hello Takayuki,
That version is fixed in Rev 5 that is on the web. And yes it was a mistake between Mx6UL and MX6DQ.
https://www.nxp.com/docs/en/reference-manual/IMX6DQRM.pdf
2 返答(返信)
1,348件の閲覧回数
Bio_TICFSL
Hello Takayuki,
1,347件の閲覧回数
takayuki_ishii
Contributor V
Thank you for your reply.
I will check difference between rev.4 and rev.5
Ishii.
