What folder can i find wireless card driver(ex. athxx.ko) file? (YOCTO)
1,237件の閲覧回数
hanseunglee
Hello everyone.
my configure below----------
YOCTO  image-core-minimal BSP
kernel : 3.14.52
ununtu 14.04
imx6dl-sabresd
I have just simple question!
$bitbake -c menuconfig virtual/kernel
and check (*)Device driver -> Network device support-> wireless LAN -> Atheros wireless cards -> (*) atheros 802.11ac wireless cards support -> (*) Athros ath10k PCI support
save and exit.
$bitbake virtual/kernel -c compile -f
and then BUILD done.
what folder can i check athxx.ko or other name driver file?
what folder can i find rootfs.tar.bz2 file for downloading use MFGTOOL?
please, reply.
Thank you.
Han.
3 返答(返信)
1,122件の閲覧回数
jimmychan
you can use 'find' command to search the file.
e.g.
find . -name athxx.ko  (to search the exactly filename)
OR
find . |grep athxx  (to search with the part of the filename)
1,122件の閲覧回数
hanseunglee
Thank you for your time.
But i already use find command. I can not find file.  OTL..
When i use LTIB system then i can find .ko file ($ltib/rootfs/lib/modules/.../kernel/driver/net)
1,122件の閲覧回数
jimmychan
.ko is a module file. You need to build the driver as a module.
The built u-boot, kernel and rootfs images can be found in the <yocto build folder>/tmp/deploy/images/<board>/
