What are the "acitvities" which will reset the timer in /sys/module/kernel/parameters/consoleblank ?
Search instead for
karthik_b
I could find that /sys/module/kernel/parameters/consoleblank is the place where the screen blank time is present and "echo -e '\033[9;0]' > /dev/tty1"  will reduce that time to 0 which basically means screen will never go blank. For me the default value is 600 which basically means after 10 mins of inactivity, the screen goes blank. But i am trying to understand  couple of things.
   1.  What are the "activities" that reset this timer ?
   2. Can we control this timer from user space ? If so, how can we ?
Can anyone help me with any kind of guidance or documentation or links ?
Thank you for your time.
Hi Karthik
one can check common linux display power management documentation
Display Power Management Signaling - ArchWiki
karthik_b
Hi Igor,
Thanks for the link. But i have already gone through the link and i coundn't find my answers there. This is one another link where i could find the tty "commands" to modify the screen configurations.
Hi Karthik
since this is general linux question it may be posted on kernel mail list.
Majordomo Lists at VGER.KERNEL.ORG
karthik_b
Sure Igor. I will try there too. Thank you.
