Hello community,
Our product is a battery-powered portable device.
We do not use Linux BSP but ROTS for this product.
In this product, some i.MX7D devices have a very large VDD_SOC leakage current
during power saving, resulting in a very short standby time.
So we plan to control SW_SOC_PD switch.
In following community thread, it say that
please refer to section 5.5.11 (GPC PGC Memory Map/Register Definition) of i.MX 7Dual Applications Processor Reference Manual, Rev. 0.1, 08/2016
How to control the i.MX7D integrated power switches ON/OFF
However, while the six switches and corresponding registers can be guessed, SW_SOC_PD and SW_FUSE are not clear.
Q1. Is the ON/OFF bit of SW_SOC_PD correct with the PCR bit (bit 0) of the GPC PGC Control Register (GPC_PGC_MIX_CTRL)?
We are currently reviewing the power saving implementation by comparing it with the Linux BSP source code.
In Linux source code "/drivers/soc/imx/gpcv2.c", it say that
* The PGC offset values in Reference Manual
* (Rev. 1, 01/2018 and the older ones) GPC chapter's
* GPC_PGC memory map are incorrect, below offset
* values are from design RTL.
#define IMX7_PGC_MIPI 16
#define IMX7_PGC_PCIE 17
#define IMX7_PGC_USB_HSIC 20
#define GPC_PGC_CTRL(n) (0x800 + (n) * 0x40)
#define GPC_PGC_SR(n) (GPC_PGC_CTRL(n) + 0xc)
And optee-os source "/core/drivers/pm/imx/suspend/psci-suspend-imx7.S"
#define MX7_SRC_GPR1 0x74
#define MX7_SRC_GPR2 0x78
#define GPC_PGC_C0 0x800
#define GPC_PGC_FM 0xa00
So it have difference between reference manual and Linux BSP source code.
PGC module name | Reference Manual | Linux BSP code |
PGC for A7 core0 | 0x303A_0800 | 0x303A_0800 |
PGC for A7 core1 | 0x303A_0840 | |
PGC for A7 SCU | 0x303A_0880 | |
PGC for fastmix/megamix | 0x303A_0890(GPC_PGC_SCU_AUXSW?) 0x303A_08C0(GPC_PGC_MIX_CTRL?) | 0x303A_0A00(GPC_PGC_FM) |
PGC for MIPI PHY | 0x303A_0900 | 0x303A_0C00 BASE + (0x800 + (16) * 0x40) |
PGC for PCIE_PHY | 0x303A_940 | 0x303A_0C40 BASE + (0x800 + (17) * 0x40) |
PGC for USB HSIC PHY | 0x303A_0D00 | 0x303A_0D00 BASE + (0x800 + (20) * 0x40) |
Q2. Which is correct address?
Ishii.
Hi @takayuki_ishii!
Thank you for contacting NXP Support!
You have to refer to the Reference Manual.
Best Regards!
Chavira
