What NXP LVGL supported development Kit can I use for Industrial HMI TFT LCD Touchscreen?
gurk
Hello, I am new to the NXP community and am trying to figure out how I can use a development kit that is LVGL compatible with a TFT LCD Touchscreen for an HMI Industrial GUI I am creating. I want to build the GUI to target a larger 10"x10" screen but all the screen I find on NXP are smaller. If I target a smaller resolution will my UI scale out to a larger screen?
Would someone be able to advise on a developmetn board kit and TFT LCD Captive Touchscreen?
Thank you!
Edit: Would a Screen like this one be compatible?
https://newhavendisplay.com/10-1-inch-ips-capacitive-tft-display/
brian14
Hi @gurk
Thank you for contacting NXP Support.
First, are you trying to connect this display to the i.MX microprocessors or i.MX RT microcontrollers?
This is a community section for i.MX microprocessors and if you are referring to the last one, please create another question in the correct section.
In any case you can implement this type of display for both devices with some changes and implementing different operating systems. In addition to that, you can use our software GUI Guider that uses LVGL library to design and create your UI for i.MX or i.MX RT.
GUI Guider | NXP Semiconductors
I hope this information will be helpful.
Have a great day!
