We are experiencing crashes with Chromium on the i.MX 8M Plus (i.MX8MP) with 2GB of RAM running Yoct
charleshuang
Senior Contributor II
We are experiencing crashes with Chromium on the i.MX 8M Plus (i.MX8MP) with 2GB of RAM running Yocto 5.0.
result:
2G RAM FAIL
6G RAM Pass.
Do you have any idea for fixed the issue?
Test tool install:
FF_Browser_issue.7z
  1. sudo dpkg -i libcxx_18.1.4-r0_arm64.deb
  2. sudo dpkg -i libxslt_1.1.39-r0_arm64.deb
  3. sudo dpkg -i nspr_4.35-r0_arm64.deb
  4. sudo dpkg -i nss_3.98-r0_arm64.deb
  5. sudo dpkg -i upower_0.99.17-r0_arm64.deb
  6. sudo dpkg -i chromium-ozone-wayland_117.0.5938.132-r0_arm64.deb
  7. Test command:
    1. chromium –no-sandbox
pengyong_zhang
Hi @charleshuang
i agree with this recommendation.
B.R
pengyong_zhang
Hi @charleshuang
B.R
pengyong_zhang
charleshuang
Hi @pengyong_zhang
Regarding the conclusion from the December 10 meeting with NXP (Wes Li) and WPI (Jimmy Chen and Andy Chien), both NXP and WPI agreed that upgrading the RAM to 4GB is required in order to resolve this issue.
Reference :  NXP Bio_TICFSL feedback:
If it the BSP what you are tying to build, the galcore need at least 4GB or modify the source code. The MX8Mplus can boot from 2GB but to run complete the BSP you need 4GB
https://community.nxp.com/t5/i-MX-Processors/imx8mp-How-to-slove-Galcore-crash/m-p/1526490#M195489
We would like to confirm whether you agree with this recommendation.
pengyong_zhang
Hi @charleshuang
Please share me your dts file. i will help you check it.
B.R
charleshuang
Hi NXP @pengyong_zhang
My dts (imx8mp-rsb3720-a1.dts) github link
https://github.com/ADVANTECH-Corp/linux-imx/blob/adv_5.4.70_2.3.0/arch/arm64/boot/dts/freescale/imx8...
Do you mean we need to add "gpu_reserved" in my dts?
pengyong_zhang
Hi @charleshuang
Please also change the gpu_reserved node as following. If it still can not work, then the smallest DDR size is 4GB, you can not use just 2GB DRAM size.
gpu_reserved: gpu_reserved@80000000 {
      no-map;
      reg = <0 0x80000000 0 0x8000000>;
B.R
pengyong_zhang
Hi @charleshuang
Try to use below command,
echo 134217728 > /sys/module/galcore/parameters/contiguousSize
Because i have no 2GB DDR on my site, so i can not reproduce your request. you need to try it on your board.
B.R
charleshuang
Hi @pengyong_zhang
Still fail. (system crash)
pengyong_zhang
Hi @charleshuang
So the question is: Can we still use the 2GB RAM configuration?
>>>the answer is yes! you can use the 2GB RAM. But you need to change the CMA and galcore.contiguousSize to fit the 2Gb RAM. For example. you can change the CMA size equal 512MB and galcore.contiguousSize equal 128MB. But i do not suggest you change it, because this would obviously reduce performance. So the best choose is use your 6GB RAM. May i know why are you use 2GB, not 6GB?
B.R
charleshuang
If I will be to change the CMA size equal 512MB , galcore.contiguousSize setting 128Mb.
How to do it?
For example : Modify Kernek dts
reserved-memory {
#address-cells = <2>;
#size-cells = <2>;
ranges;
linux,cma {
compatible = "shared-dma-pool";
reusable;
size = <0x0 0x20000000>; /* 512MB */
alignment = <0x0 0x400000>; /* 4MB alignment */
linux,cma-default;
pengyong_zhang
Hi @charleshuang
Can you pass the DDR stress test with DDR Config Tool ? About your 2GB DDR.
B.R
charleshuang
Hi @pengyong_zhang
The pass.
charleshuang
Regarding the community issue, NXP provided feedback about the Galcore crash:
NXP Bio_TICFSK feedback:
If this is the BSP you are trying to build, Galcore requires at least 4GB of RAM, or you need to modify the source code. The i.MX8M Plus can boot with 2GB, but to run the full BSP you need 4GB. Chromium also uses Galcore.
pengyong_zhang
Hi @charleshuang
What is you 2GB DRAM type? Can you pass the DDR stress test with our DDR Config Tool?
B.R
charleshuang
Hi @pengyong_zhang
The attachment file "MX8M_Plus_LPDDR4_RPA_v10" is DDR tools excel.
We try test it again.
The result is fail (crashes with Chromium ).
Do you have any idea?
Thanks.
charleshuang
pengyong_zhang
Hi @charleshuang
Please try the below command:
chromium --disable-gpu --disable-software-rasterizer --disable-extensions --disable-background-networking --disable-sync --disable-translate --disable-features=SitePerProcess --no-sandbox
B.R
Jems-advantech
Thank you for providing the test command. I have executed the test as suggested, but unfortunately, the Chromium browser still hangs and eventually crashes. After the crash, the desktop becomes completely unusable; however, the debug console remains operational.
Here is the running information:
The memory size remains around 1.4 GB, but some error messages appear.
After the desktop crash, I executed dmesg in the debug console, and additional error messages were observed.
Attached is the full log for your reference.
Kindly let me know if there are any additional steps or alternative approaches you would recommend.
%3CLINGO-SUB%20id%3D%22lingo-sub-2190611%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EWe%20are%20experiencing%20crashes%20with%20Chromium%20on%20the%20i.MX%208M%20Plus%20(i.MX8MP)%20with%202GB%20of%20RAM%20running%20Yoct%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2190611%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EWe%20are%20experiencing%20crashes%20with%20Chromium%20on%20the%20i.MX%208M%20Plus%20(i.MX8MP)%20with%202GB%20of%20RAM%20running%20Yocto%205.0.%3C%2FP%3E%3CP%3Eresult%3A%3C%2FP%3E%3CP%3E2G%20RAM%20FAIL%3C%2FP%3E%3CP%3E6G%20RAM%20Pass.%3C%2FP%3E%3CBR%20%2F%3E%3CP%3EDo%20you%20have%20any%20idea%20for%20fixed%20the%20issue%3F%3C%2FP%3E%3CP%3ETest%20tool%20install%3A%3C%2FP%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fadvantecho365-my.sharepoint.com%2F%3Au%3A%2Fg%2Fpersonal%2Fjems_cheng_advantech_com%2FEUbgi_jKcbpGulIaH1NJdbMBbnNC0GIHiLjCYkkMRR82Hw%3Fe%3DanUAlX%26amp%3Bxsdata%3DMDV8MDJ8Q2xheWRlci5IdWFuZ0BhZHZhbnRlY2guY29tLnR3fDhmMzM4NmFhYjZlNDQ2NDMwZTc1MDhkZGY1OWZhYmI4fGE3N2Q0MGQ5ZGNiYTRkZGFiNTcxNWYxOGU2ZGE4NTNmfDB8MHw2Mzg5MzY3ODgzODY0MTQ4Njl8VW5rbm93bnxUV0ZwYkdac2IzZDhleUpGYlhCMGVVMWhjR2tpT25SeWRXVXNJbFlpT2lJd0xqQXVNREF3TUNJc0lsQWlPaUpYYVc0ek1pSXNJa0ZPSWpvaVRXRnBiQ0lzSWxkVUlqb3lmUT09fDB8fHw%253d%26amp%3Bsdata%3DN1NCakhORHNFSHExVlE1cm1RNGcrT0tIQlUxS1lqYjlkM0g1aGNKbXg5OD0%253d%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3EFF_Browser_issue.7z%3C%2FA%3E%3C%2FP%3E%3COL%3E%3CLI%3Esudo%20dpkg%20-i%20libcxx_18.1.4-r0_arm64.deb%3C%2FLI%3E%3CLI%3Esudo%20dpkg%20-i%20libxslt_1.1.39-r0_arm64.deb%3C%2FLI%3E%3CLI%3Esudo%20dpkg%20-i%20nspr_4.35-r0_arm64.deb%3C%2FLI%3E%3CLI%3Esudo%20dpkg%20-i%20nss_3.98-r0_arm64.deb%3C%2FLI%3E%3CLI%3Esudo%20dpkg%20-i%20upower_0.99.17-r0_arm64.deb%3C%2FLI%3E%3CLI%3Esudo%20dpkg%20-i%20chromium-ozone-wayland_117.0.5938.132-r0_arm64.deb%3C%2FLI%3E%3CLI%3E%3CP%3ETest%20command%3A%3C%2FP%3E%3COL%3E%3CLI%3Echromium%20%E2%80%93no-sandbox%3C%2FLI%3E%3C%2FOL%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%222G_1.jpg%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%222G_1.jpg%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%222G_1.jpg%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%222G_1.jpg%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%222G_1.jpg%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%222G_1.jpg%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%222G_1.jpg%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%222G_1.jpg%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%222G_1.jpg%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%222G_1.jpg%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%222G_1.jpg%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%222G_1.jpg%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%222G_1.jpg%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%222G_1.jpg%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%222G_1.jpg%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F362057iF3CAAE16031B1FF9%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%222G_1.jpg%22%20alt%3D%222G_1.jpg%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%222G_2.jpg%22%20style%3D%22width%3A%20770px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%222G_2.jpg%22%20style%3D%22width%3A%20770px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%222G_2.jpg%22%20style%3D%22width%3A%20770px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%222G_2.jpg%22%20style%3D%22width%3A%20770px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%222G_2.jpg%22%20style%3D%22width%3A%20770px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%222G_2.jpg%22%20style%3D%22width%3A%20770px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%222G_2.jpg%22%20style%3D%22width%3A%20770px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%222G_2.jpg%22%20style%3D%22width%3A%20770px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%222G_2.jpg%22%20style%3D%22width%3A%20770px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%222G_2.jpg%22%20style%3D%22width%3A%20770px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%222G_2.jpg%22%20style%3D%22width%3A%20770px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%222G_2.jpg%22%20style%3D%22width%3A%20770px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%222G_2.jpg%22%20style%3D%22width%3A%20770px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%222G_2.jpg%22%20style%3D%22width%3A%20770px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%222G_2.jpg%22%20style%3D%22width%3A%20770px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F362056iFE01741F548FCEBE%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%222G_2.jpg%22%20alt%3D%222G_2.jpg%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FLI%3E%3C%2FOL%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%222G_3.jpg%22%20style%3D%22width%3A%20901px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%222G_3.jpg%22%20style%3D%22width%3A%20901px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%222G_3.jpg%22%20style%3D%22width%3A%20901px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%222G_3.jpg%22%20style%3D%22width%3A%20901px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%222G_3.jpg%22%20style%3D%22width%3A%20901px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%222G_3.jpg%22%20style%3D%22width%3A%20901px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%222G_3.jpg%22%20style%3D%22width%3A%20901px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%222G_3.jpg%22%20style%3D%22width%3A%20901px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%222G_3.jpg%22%20style%3D%22width%3A%20901px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%222G_3.jpg%22%20style%3D%22width%3A%20901px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%222G_3.jpg%22%20style%3D%22width%3A%20901px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%222G_3.jpg%22%20style%3D%22width%3A%20901px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%222G_3.jpg%22%20style%3D%22width%3A%20901px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%222G_3.jpg%22%20style%3D%22width%3A%20901px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%222G_3.jpg%22%20style%3D%22width%3A%20901px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F362059i988CA05E3B441215%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%222G_3.jpg%22%20alt%3D%222G_3.jpg%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-2190611%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3Ei.MX%208%20Family%20%7C%20i.MX%208QuadMax%20(8QM)%20%7C%208QuadPlus%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3Ei.MX%208M%20%7C%20i.MX%208M%20Mini%20%7C%20i.MX%208M%20Nano%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2205730%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20We%20are%20experiencing%20crashes%20with%20Chromium%20on%20the%20i.MX%208M%20Plus%20(i.MX8MP)%20with%202GB%20of%20RAM%20running%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2205730%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F43469%22%20target%3D%22_blank%22%3E%40charleshuang%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3EWhat%20is%20you%202GB%20DRAM%20type%3F%20Can%20you%20pass%20the%20DDR%20stress%20test%20with%20our%20DDR%20Config%20Tool%3F%3C%2FP%3E%0A%3CP%3EB.R%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2204020%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20We%20are%20experiencing%20crashes%20with%20Chromium%20on%20the%20i.MX%208M%20Plus%20(i.MX8MP)%20with%202GB%20of%20RAM%20running%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2204020%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EThank%20you%20for%20providing%20the%20test%20command.%20I%20have%20executed%20the%20test%20as%20suggested%2C%20but%20unfortunately%2C%26nbsp%3Bthe%20Chromium%20browser%20still%20hangs%20and%20eventually%20crashes.%20After%20the%20crash%2C%20the%20desktop%20becomes%20completely%20unusable%3B%20however%2C%20the%20debug%20console%20remains%20operational.%3C%2FP%3E%3CP%3EHere%20is%20the%20running%20information%3A%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Jemsadvantech_0-1762999258809.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Jemsadvantech_0-1762999258809.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Jemsadvantech_0-1762999258809.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Jemsadvantech_0-1762999258809.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Jemsadvantech_0-1762999258809.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Jemsadvantech_0-1762999258809.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Jemsadvantech_0-1762999258809.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Jemsadvantech_0-1762999258809.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Jemsadvantech_0-1762999258809.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Jemsadvantech_0-1762999258809.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Jemsadvantech_0-1762999258809.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Jemsadvantech_0-1762999258809.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Jemsadvantech_0-1762999258809.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Jemsadvantech_0-1762999258809.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Jemsadvantech_0-1762999258809.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F365383i84AE6C2B5DCE46F4%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Jemsadvantech_0-1762999258809.png%22%20alt%3D%22Jemsadvantech_0-1762999258809.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3EThe%20memory%20size%20remains%20around%20%3CSTRONG%3E1.4%20GB%3C%2FSTRONG%3E%2C%20but%20some%20error%20messages%20appear.%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Jemsadvantech_1-1762999343340.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Jemsadvantech_1-1762999343340.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Jemsadvantech_1-1762999343340.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Jemsadvantech_1-1762999343340.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Jemsadvantech_1-1762999343340.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Jemsadvantech_1-1762999343340.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Jemsadvantech_1-1762999343340.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Jemsadvantech_1-1762999343340.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Jemsadvantech_1-1762999343340.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Jemsadvantech_1-1762999343340.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Jemsadvantech_1-1762999343340.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Jemsadvantech_1-1762999343340.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Jemsadvantech_1-1762999343340.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Jemsadvantech_1-1762999343340.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Jemsadvantech_1-1762999343340.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F365384iDA245227B00C55CB%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Jemsadvantech_1-1762999343340.png%22%20alt%3D%22Jemsadvantech_1-1762999343340.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3EAfter%20the%20desktop%20crash%2C%20I%20executed%20dmesg%20in%20the%20debug%20console%2C%20and%20additional%20error%20messages%20were%20observed.%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Jemsadvantech_2-1762999362807.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Jemsadvantech_2-1762999362807.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Jemsadvantech_2-1762999362807.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Jemsadvantech_2-1762999362807.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Jemsadvantech_2-1762999362807.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Jemsadvantech_2-1762999362807.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Jemsadvantech_2-1762999362807.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Jemsadvantech_2-1762999362807.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Jemsadvantech_2-1762999362807.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Jemsadvantech_2-1762999362807.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Jemsadvantech_2-1762999362807.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Jemsadvantech_2-1762999362807.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Jemsadvantech_2-1762999362807.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Jemsadvantech_2-1762999362807.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Jemsadvantech_2-1762999362807.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F365385i6B11787DE7A86F2D%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Jemsadvantech_2-1762999362807.png%22%20alt%3D%22Jemsadvantech_2-1762999362807.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3EAttached%20is%20the%20full%20log%20for%20your%20reference.%3C%2FP%3E%3CBR%20%2F%3E%3CP%3EKindly%20let%20me%20know%20if%20there%20are%20any%20additional%20steps%20or%20alternative%20approaches%20you%20would%20recommend.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2190644%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20We%20are%20experiencing%20crashes%20with%20Chromium%20on%20the%20i.MX%208M%20Plus%20(i.MX8MP)%20with%202GB%20of%20RAM%20running%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2190644%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F43469%22%20target%3D%22_blank%22%3E%40charleshuang%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3EPlease%20try%20the%20below%20command%3A%3C%2FP%3E%0A%3CPRE%3E%3CCODE%3Echromium%20--disable-gpu%20--disable-software-rasterizer%20--disable-extensions%20--disable-background-networking%20--disable-sync%20--disable-translate%20--disable-features%3DSitePerProcess%20--no-sandbox%0A%60%60%3C%2FCODE%3E%3C%2FPRE%3E%0A%3CP%3EB.R%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2254820%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20We%20are%20experiencing%20crashes%20with%20Chromium%20on%20the%20i.MX%208M%20Plus%20(i.MX8MP)%20with%202GB%20of%20RAM%20running%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2254820%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F43469%22%20target%3D%22_blank%22%3E%40charleshuang%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3ECan%20you%20pass%20the%20DDR%20stress%20test%20with%20%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdesign%2Fdesign-center%2Fdevelopment-boards-and-designs%2Fi-mx-evaluation-and-development-boards%2Fconfig-tools-for-i-mx-applications-processors%3ACONFIG-TOOLS-IMX%22%20target%3D%22_self%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3EDDR%20Config%20Tool%26nbsp%3B%3C%2FA%3E%3F%20About%20your%202GB%20DDR.%3C%2FP%3E%0A%3CP%3EB.R%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2254092%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20We%20are%20experiencing%20crashes%20with%20Chromium%20on%20the%20i.MX%208M%20Plus%20(i.MX8MP)%20with%202GB%20of%20RAM%20running%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2254092%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F202673%22%20target%3D%22_blank%22%3E%40pengyong_zhang%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%3CP%3EThe%20attachment%20file%20%22MX8M_Plus_LPDDR4_RPA_v10%22%20is%20DDR%20tools%20excel.%3C%2FP%3E%3CP%3EWe%20try%20test%20it%20again.%3C%2FP%3E%3CP%3EThe%20result%20is%20fail%20(crashes%20with%20Chromium%20).%3C%2FP%3E%3CP%3EDo%20you%20have%20any%20idea%3F%3C%2FP%3E%3CP%3EThanks.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2254096%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20We%20are%20experiencing%20crashes%20with%20Chromium%20on%20the%20i.MX%208M%20Plus%20(i.MX8MP)%20with%202GB%20of%20RAM%20running%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2254096%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CSPAN%3EThe%20attachment%20file%20%22MX8M_Plus_LPDDR4_RPA_v10%22%20is%20DDR%20tools%20excel.%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2255977%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20We%20are%20experiencing%20crashes%20with%20Chromium%20on%20the%20i.MX%208M%20Plus%20(i.MX8MP)%20with%202GB%20of%20RAM%20running%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2255977%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%20NXP%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F202673%22%20target%3D%22_blank%22%3E%40pengyong_zhang%3C%2FA%3E%26nbsp%3B%26nbsp%3B%3C%2FP%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fi-MX-Processors%2Fimx8mp-How-to-slove-Galcore-crash%2Fm-p%2F1526490%23M195489%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fi-MX-Processors%2Fimx8mp-How-to-slove-Galcore-crash%2Fm-p%2F1526490%23M195489%3C%2FA%3E%3C%2FP%3E%3CP%3ERegarding%20the%20community%20issue%2C%20NXP%20provided%20feedback%20about%20the%20Galcore%20crash%3A%3C%2FP%3E%3CP%3E%3CSTRONG%3ENXP%20Bio_TICFSK%20feedback%3A%3C%2FSTRONG%3E%3CBR%20%2F%3EIf%20this%20is%20the%20BSP%20you%20are%20trying%20to%20build%2C%20Galcore%20requires%20at%20least%204GB%20of%20RAM%2C%20or%20you%20need%20to%20modify%20the%20source%20code.%20The%20i.MX8M%20Plus%20can%20boot%20with%202GB%2C%20but%20to%20run%20the%20full%20BSP%20you%20need%204GB.%20Chromium%20also%20uses%20Galcore.%3C%2FP%3E%3CP%3ESo%20the%20question%20is%3A%20%3CSTRONG%3ECan%20we%20still%20use%20the%202GB%20RAM%20configuration%3F%3C%2FSTRONG%3E%3C%2FP%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2256599%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20We%20are%20experiencing%20crashes%20with%20Chromium%20on%20the%20i.MX%208M%20Plus%20(i.MX8MP)%20with%202GB%20of%20RAM%20running%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2256599%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F43469%22%20target%3D%22_blank%22%3E%40charleshuang%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3E%3CSPAN%3ESo%20the%20question%20is%3A%26nbsp%3B%3C%2FSPAN%3E%3CSTRONG%3ECan%20we%20still%20use%20the%202GB%20RAM%20configuration%3F%3C%2FSTRONG%3E%3C%2FP%3E%0A%3CP%3E%26gt%3B%26gt%3B%26gt%3Bthe%20answer%20is%20yes!%20you%20can%20use%20the%202GB%20RAM.%20But%20you%20need%20to%20change%20the%20CMA%20and%20galcore.contiguousSize%20to%20fit%20the%202Gb%20RAM.%20For%20example.%20you%20can%20change%20the%20CMA%20size%20equal%20512MB%20and%26nbsp%3Bgalcore.contiguousSize%20equal%20128MB.%20But%20i%20do%20not%20suggest%20you%20change%20it%2C%20because%20this%20would%20obviously%20reduce%20performance.%20So%20the%20best%20choose%20is%20use%20your%206GB%20RAM.%20May%20i%20know%20why%20are%20you%20use%202GB%2C%20not%206GB%3F%3C%2FP%3E%0A%3CP%3E%3CSTRONG%3E%3CSPAN%3EB.R%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2256653%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20We%20are%20experiencing%20crashes%20with%20Chromium%20on%20the%20i.MX%208M%20Plus%20(i.MX8MP)%20with%202GB%20of%20RAM%20running%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2256653%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%20NXP%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F202673%22%20target%3D%22_blank%22%3E%40pengyong_zhang%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%3CP%3EIf%20I%20will%20be%20to%20change%20the%20CMA%20size%20equal%20512MB%20%2C%20galcore.contiguousSize%20setting%20128Mb.%3C%2FP%3E%3CP%3EHow%20to%20do%20it%3F%3C%2FP%3E%3CP%3EFor%20example%20%3A%20Modify%20Kernek%20dts%3C%2FP%3E%3CP%3Ereserved-memory%20%7B%3CBR%20%2F%3E%23address-cells%20%3D%20%26lt%3B2%26gt%3B%3B%3CBR%20%2F%3E%23size-cells%20%3D%20%26lt%3B2%26gt%3B%3B%3CBR%20%2F%3Eranges%3B%3C%2FP%3E%3CP%3Elinux%2Ccma%20%7B%3CBR%20%2F%3Ecompatible%20%3D%20%22shared-dma-pool%22%3B%3CBR%20%2F%3Ereusable%3B%3CBR%20%2F%3Esize%20%3D%20%26lt%3B0x0%200x20000000%26gt%3B%3B%20%2F*%20512MB%20*%2F%3CBR%20%2F%3Ealignment%20%3D%20%26lt%3B0x0%200x400000%26gt%3B%3B%20%2F*%204MB%20alignment%20*%2F%3CBR%20%2F%3Elinux%2Ccma-default%3B%3CBR%20%2F%3E%7D%3B%3CBR%20%2F%3E%7D%3B%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2257540%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20We%20are%20experiencing%20crashes%20with%20Chromium%20on%20the%20i.MX%208M%20Plus%20(i.MX8MP)%20with%202GB%20of%20RAM%20running%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2257540%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F43469%22%20target%3D%22_blank%22%3E%40charleshuang%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3ETry%20to%20use%20below%20command%2C%26nbsp%3B%3C%2FP%3E%0A%3CPRE%3Eecho%20134217728%20%26gt%3B%20%2Fsys%2Fmodule%2Fgalcore%2Fparameters%2FcontiguousSize%3C%2FPRE%3E%0A%3CP%3EBecause%20i%20have%20no%202GB%20DDR%20on%20my%20site%2C%20so%20i%20can%20not%20reproduce%20your%20request.%20you%20need%20to%20try%20it%20on%20your%20board.%3C%2FP%3E%0A%3CP%3EB.R%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2257740%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20We%20are%20experiencing%20crashes%20with%20Chromium%20on%20the%20i.MX%208M%20Plus%20(i.MX8MP)%20with%202GB%20of%20RAM%20running%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2257740%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F202673%22%20target%3D%22_blank%22%3E%40pengyong_zhang%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%3CP%3EStill%20fail.%20(system%20crash)%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22image.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22image.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22image.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22image.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22image.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22image.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22image.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F369090iDAC3CC36BEAB8E0A%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22image.png%22%20alt%3D%22image.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E2%80%83%3C%2FP%3E%3CDIV%20class%3D%22%22%3E%26nbsp%3B%3C%2FDIV%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2258542%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20We%20are%20experiencing%20crashes%20with%20Chromium%20on%20the%20i.MX%208M%20Plus%20(i.MX8MP)%20with%202GB%20of%20RAM%20running%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2258542%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F43469%22%20target%3D%22_blank%22%3E%40charleshuang%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3EPlease%20also%20change%20the%20gpu_reserved%20node%20as%20following.%20If%20it%20still%20can%20not%20work%2C%20then%20the%20smallest%20DDR%20size%20is%204GB%2C%20you%20can%20not%20use%20just%202GB%20DRAM%20size.%3C%2FP%3E%0A%3CPRE%3E%3CSPAN%3Egpu_reserved%3C%2FSPAN%3E%3CSPAN%3E%3A%20%3C%2FSPAN%3E%3CSPAN%3Egpu_reserved%4080000000%3C%2FSPAN%3E%3CSPAN%3E%20%7B%3C%2FSPAN%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20no-map%3B%3C%2FSPAN%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20reg%20%3D%20%26lt%3B%3C%2FSPAN%3E%3CSPAN%3E0%3C%2FSPAN%3E%20%3CSPAN%3E0x80000000%3C%2FSPAN%3E%20%3CSPAN%3E0%3C%2FSPAN%3E%20%3CSPAN%3E0x8000000%3C%2FSPAN%3E%3CSPAN%3E%26gt%3B%3B%3C%2FSPAN%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CSPAN%3E%7D%3B%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FPRE%3E%0A%3CP%3EB.R%26nbsp%3B%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2258807%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20We%20are%20experiencing%20crashes%20with%20Chromium%20on%20the%20i.MX%208M%20Plus%20(i.MX8MP)%20with%202GB%20of%20RAM%20running%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2258807%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F43469%22%20target%3D%22_blank%22%3E%40charleshuang%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3EPlease%20share%20me%20your%20dts%20file.%20i%20will%20help%20you%20check%20it.%3C%2FP%3E%0A%3CP%3EB.R%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2259660%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20We%20are%20experiencing%20crashes%20with%20Chromium%20on%20the%20i.MX%208M%20Plus%20(i.MX8MP)%20with%202GB%20of%20RAM%20running%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2259660%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F43469%22%20target%3D%22_blank%22%3E%40charleshuang%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3EYes%2C%20please%20refer%20the%20following%20link%20file%20change%20your%20dts%20file.%3C%2FP%3E%0A%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2Fnxp-imx%2Flinux-imx%2Fblob%2F7ad9f6482c318b86906c53f4db5e7d4b17398abd%2Farch%2Farm64%2Fboot%2Fdts%2Ffreescale%2Fimx8mp.dtsi%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fgithub.com%2Fnxp-imx%2Flinux-imx%2Fblob%2F7ad9f6482c318b86906c53f4db5e7d4b17398abd%2Farch%2Farm64%2Fboot%2Fdts%2Ffreescale%2Fimx8mp.dtsi%3C%2FA%3E%3C%2FP%3E%0A%3CP%3EB.R%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2260691%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20We%20are%20experiencing%20crashes%20with%20Chromium%20on%20the%20i.MX%208M%20Plus%20(i.MX8MP)%20with%202GB%20of%20RAM%20running%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2260691%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F202673%22%20target%3D%22_blank%22%3E%40pengyong_zhang%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%3CP%3ERegarding%20the%20conclusion%20from%20the%20December%2010%20meeting%20with%20NXP%20(Wes%20Li)%20and%20WPI%20(Jimmy%20Chen%20and%20Andy%20Chien)%2C%20both%20NXP%20and%20WPI%20agreed%20that%20upgrading%20the%20RAM%20to%204GB%20is%20required%20in%20order%20to%20resolve%20this%20issue.%3C%2FP%3E%3CBR%20%2F%3E%3CP%3EReference%20%3A%E3%80%80%E3%80%80NXP%20Bio_TICFSL%20feedback%3A%3C%2FP%3E%3CP%3E%3CFONT%20color%3D%22%23FF0000%22%3E%3CSPAN%3EIf%20it%20the%20BSP%20what%20you%20are%20tying%20to%20build%2C%20the%20galcore%20need%20at%20least%204GB%20or%20modify%20the%20source%20code.%20The%20MX8Mplus%20can%20boot%20from%202GB%20but%20to%20run%20complete%20the%20BSP%20you%20need%204GB%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fi-MX-Processors%2Fimx8mp-How-to-slove-Galcore-crash%2Fm-p%2F1526490%23M195489%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fi-MX-Processors%2Fimx8mp-How-to-slove-Galcore-crash%2Fm-p%2F1526490%23M195489%3C%2FA%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CBR%20%2F%3EWe%20would%20like%20to%20confirm%20whether%20you%20agree%20with%20this%20recommendation.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2262102%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20We%20are%20experiencing%20crashes%20with%20Chromium%20on%20the%20i.MX%208M%20Plus%20(i.MX8MP)%20with%202GB%20of%20RAM%20running%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2262102%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F43469%22%20target%3D%22_blank%22%3E%40charleshuang%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3Ei%20agree%20with%20this%20recommendation.%3C%2FP%3E%0A%3CP%3EB.R%3C%2FP%3E%3C%2FLINGO-BODY%3E
