I'm working with the i.MX RT1052 processor and designing a POR circuit.
I found the following circuit in the reference design but I don't understand how it's meant to work.
Surely any signal on the WDOG_B gets blocked by the C60 1uF capacitor?
Or am I missing something here?
Thanks!
Solved! Go to Solution.
Hello Josh,
The C60 and R45 works as a filter, when the WATCHDOG signal ( DC Signal only Pulse) it is generated by the Processor, this create a pulse that sends the MR and RESET to the Master reset of the board. Hope this clarifies.
TIC
Hello Josh,
TIC
