Watchdog in User Land
Lippa
I have a functional version with watchdog controlled by the kernel  but my need is to control it from my application so to deactivate it on the kernel side and reset the watchdog in my application.
How to do this in user land, is there an api exposed by a lib? or another method?
Thank you
Lippa
igorpadykov
Hi Lippa
for wdog apis one can look at unit test
https://source.codeaurora.org/external/imx/imx-test/tree/test/wdog?h=imx_5.4.24_2.1.0
and sect.2.11.8 Programming Interface i.MX Linux Reference Manual​
Some wdog fields are once written, so can not be changed
as described for example in sect.70.7.1 Watchdog Control Register (WDOGx_WCR)
i.MX 6Dual/6Quad Applications Processor Reference Manual
