Wanted i.MX35 SDK and Advanced Toolkit
已解决
跳至解决方案
1,196 次查看
AFaustas
Hello there,
I have to make some changes to a system which uses i.MX353  (MCIMX353CJQ5C) and runs  Linux 3.18.24. Could you tell me, where could I find an SDK?
I also need a tool which could read an entire NAND flash and also program it. It seems that I should use Advanced Toolkit (ATK) for that. However, all download links seems to be dead.
标签 (1)
标记 (2)
1 解答
1,139 次查看
joanxie
I send all packages what I have to you by mail, pls check
在原帖中查看解决方案
4 回复数
1,158 次查看
joanxie
imx35 is too old to find this, I only find SDK for 2.6. if you need it, I can send it to you
1,150 次查看
AFaustas
Please send me the SDK which you have.
If you can't find Advanced Toolkit, could you find any other compatible tool which could read an entire NAND flash and also program it?
标记 (2)
1,140 次查看
joanxie
1,023 次查看
AFaustas
Thank you.
