Hello Igor,
Thank you for your quick response.
I wanted to create two frame buffers and use them on a single display, but the buffer shall switch at each Vsync interrupt.
How Can I achieve the above? Where are the changes that need to be done to achieve this?
Thanks & Regards,
Kailas Kharse
