Dear All,
We are looking for SOC for using in Voip Application. The SOC should work Baremetal Software(No OS). The SDK should include SIP Protocol stack. Please suggest some SOC's and SDK's Available.
Thanks & Regards
Rama Krishna
Hi Rama,
In case of the i.MX6 series of applications processors, you could refer to the “i.MX 6Series Platform SDK”, a bare-metal SDK for the i.MX 6 series, including reusable drivers and tests for many peripherals, and much example code.
Other option (depending of the required performance) could be a Kinetis MCU, running MQX RTOS, or if you are really looking for a bare-metal option, you could refer to fNET at these links:
https://community.freescale.com/message/81528
Hope this will be useful for you.
Best regards!
/Carlos
