Vivante examples segmentation fault
1,101 次查看
manjunathjoshi
Hello all ,
I have been working on mx6 dual plus board sabresd and I saw /opt/viv_samples/vdk/tutorial examples used to work for me.
Now I am suddenly getting segmentation fault for a few.
Any one has an idea what went wrong ??
标记 (1)
863 次查看
gary_bisson
Senior Contributor III
The segfault usually happens when there is a mismatch between the kernel driver version and the user-space libraries.
So it means you either upgraded you kernel version but not the user-space libraries or the other way around.
Gary
863 次查看
jimmychan
Please use this:
i.MX6DP|i.MX 6DualPlus Processors|Dual Core|NXP
