Hi all
Let me confirm about the value of Vih and Vil for POR_B in i.MX6SL.
I'm also using PF3000 and concerning about their electrical characteristics difference.
So please tell me the following question.
Q1.
The spec is mentioned in table 21 of IMX6SLCEC..
Am I correct ?
https://www.nxp.com/docs/en/data-sheet/IMX6SLCEC.pdf
Q2.
If Q1 in wrong, could you tell me the spec ?
Ko-hey
Solved! Go to Solution.
yes,the table should be correct,
High-Level DC minimal input voltage is 0.7 OVDD, Low-Level DC maximal input voltage is 0.3 OVDD.
Could someone follow and answer this thread ?
Ko-hey
