We have designed our application board based on iMX8MQ processor. We have completed bring up of all interfaces including USB3.0 & HDMI port.
Both USB & HDMI interfaces are working fine. We are able to play saved video from USB mass storage drive to HDMI.
Now while we stream a video from Webcam USB to HDMI port. We are getting a continuous "Green screen" on HDMI 720p display and getting continuous Kernal crash logs on console. We are not able to terminate the Gstremer command using CNTL+C, the power cycle is required to do so.
See the console logs in the attached file below.
We are using below Gstreamer command:
gst-launch-1.0 v4l2src device=/dev/video2 ! 'video/x-raw,format=YUY2' ! glimagesink
What we are changing in the kernel so that we are getting this issue in 4.14.78 but not in 4.14.98 kernel.
Is there any idea.
I want to fix this issue in 4.14.78. Is there any patch or code change available?
Chaitanya Sonagara
Unfortunately, we do not have any patch to make this work. What I suggest you are to compare both drivers and see what are the difference to update in the latest kernel. Unfortunately, this is out of our scope of support.
Diego.
ok, I will go through it.
Thanks for your support.
Chaitanya Sonagara
Have you tried adding sync=false at the end of the glimagesink? If not, try using as sink source waylandsink. This is working on my EVK board.
Diego.
Hi Diego,
Thanks for your replay.
I tried with sync=false and waylandsink but it is not working for me.I am getting same cress.
commands are:
- gst-launch-1.0 v4l2src device=/dev/video1 ! 'video/x-raw,format=YUY2' ! glimagesink sync=false
- gst-launch-1.0 v4l2src device=/dev/video1 ! 'video/x-raw,format=YUY2' ! waylandsink
Chaitanya Sonagara
Is there any update on this issue.
I am thinking it is "AXI BUS ERROR" anyone has an idea about it?
What Linux version are you using?
Diego.
Hi Diego,
I am using 4.14.78 Linux version.
Chaitanya Sonagara
I have tested with that version and I have found the problem that you encountered. However, on the L4.14.98 version, the problem is not presented. I suggest you change to that version.
I used the following pipeline.
gst-launch-1.0 v4l2src device=/dev/video2 ! 'video/x-raw,format=YUY2' ! waylandsink sync=false
Hope this may help you.
Diego.
Hi Diego,
I tried with kernel version 4.14.98. Problem solved after changing the kernel version 4.14.78 to 4.14.98.
Chaitanya Sonagara
