Video output on USB-C on imx8m plus
已解决
跳至解决方案
6,167 次查看
inzenjer-banderas
Hello everybody,
We are planning to use an IMX8M PLUS based board for an embedded application which would include some sort of a screen to display graphical data. Since HDMI is not an option, I was wondering if it was possible to configure any Linux distribution/BSP to output video on its USB-C interface?
I must say that I am by no means expert in video related technologies and therefore couldn't find this information nor make much sense of other sources on the internet.
Lazar
标签 (2)
标记 (1)
1 解答
6,158 次查看
Bio_TICFSL
The kernel 5.10 and up, can do that, but you will need to have a module that its not implemented for MX8MP.
在原帖中查看解决方案
9 回复数
6,149 次查看
inzenjer-banderas
Thank you for your prompt answer. Just one more question, by module you mean software module, right?
Best Regards
5,796 次查看
guysoft
Hey,
Did you manage to figure out which driver/device tree setting is needed to get this to work?
Thanks!
6,140 次查看
Bio_TICFSL
Yes, that's correct
6,134 次查看
inzenjer-banderas
Thank you very much.
5,251 次查看
relaxibus
Hi, can you disclose if it works? I'm also looking for the same. Would like to use either VGA or HDMI.
5,241 次查看
inzenjer-banderas
Hello @relaxibus, at the end I  gave up trying to do it with USB, so I cannot confirm whether it works or not. Maybe somebody from NXP can tell us if that kernel module has been implemented for iMX8MP or not?
5,238 次查看
relaxibus
Thanks, I made a reply to NXP here, you can see the driver links now available for Ubuntu. May be it helps to achieve the goal.
6,159 次查看
Bio_TICFSL
5,239 次查看
relaxibus
Hi, I'm also looking for the same. Would like to use either VGA or HDMI. Will it works now with the USB 3.0 driver for Displaylink: https://www.synaptics.com/products/displaylink-graphics/downloads/ubuntu
https://support.displaylink.com/knowledgebase/articles/683482-displaylink-support-for-ubuntu-now-ava...
