Dear all,
Product data sheets such as i.MX6 and i.MX8X have the following note regarding VIH / VIL.
*This is an excerpt from i.MX8X datasheet(https://www.nxp.com/docs/en/data-sheet/IMX8QXPAEC.pdf).
But I can't find that in the i.MX8M datasheet(https://www.nxp.com/docs/en/data-sheet/IMX8MDQLQCEC.pdf).
In general, I think there should be such a note, but is it omission?
George
Solved! Go to Solution.
Yes, you are right, the same note is applicaple to the i.MX8M I/Os as well.
Artur
Artur
Dear Artur,
Thank you for your quick respons.
BR,
George
