VC imx296 on imx8mp
VC imx296 on imx8mp
2,905 次查看
lutze
i am trying to use a Vision Components imx296 camera with an imx8mp (on a toradex verdin module). The i2c driver was written for the imx8qp modules, but seems to work on the imx8mp. But streaming frames i get somehow an incomplete buffer, where a part somehow is repeated. The Picture in Y10 -format should be 1440x1080 pixel. The attached file shows the image i get.
My changes to the devicetree are the following:
2,886 次查看
khang_letruong
Senior Contributor III
Hi @lutze,
Hope you find the following link helpful : https://github.com/pmliquify/vc_mipi_imx8mp
Khang
2,854 次查看
lutze
Hello khang letruong,
thank for your reply. I already tried that driver and the changes that it does to the mipi driver. This one is working.
I want to use a newer kernel version and also use a imx392, so i am using this i2c driver:
