V4L2 based video scale down application for imx6q
1,682件の閲覧回数
jemish_1990
Hi All,
We have two requirements.
1. Is it possible to capture custom resolutions  (example : 480x 272 ) by imx6q?
2. In second requirement we are able to capture NTSC (720 X 480) video in imx6q . Now is there any v4l2 based application available to scale down video to custom resolution (example 480x272).
Please let me know if any of the option is possible.
Jemish
ラベル(2)
6 返答(返信)
1,115件の閲覧回数
Hi Jemish
one can look at unit test examples, read doc folder in ../test/mxc_v4l2_test/
http://downloads.yoctoproject.org/mirror/sources/imx-test-5.2.tar.gz
it is also described in attached Linux Manual sect.6.4.2 Video4Linux API test
resize examples in:
https://community.freescale.com/docs/DOC-94961
1,115件の閲覧回数
jemish_1990
Hi Igor,
Thanks a lot for your suggestion!
We made it working as of now by doing few changes in sample application we were using.
We can close this thread as of now. If needed I will open new thread.
Once again thank a lot for your suggestions.
Jemish
1,115件の閲覧回数
jemish_1990
Hi Igor,
One quick question if I am using
Below API for scale down.
VIDIOC_S_CROP
How can we confirm whether it is using hw scaler (IPU) or ARM cpu?
Jemish
1,115件の閲覧回数
Hi Jemish
one can look at attached Linux Manual sect.9.2 V4L2 Capture Device
shows used VIDIOC.
1,115件の閲覧回数
jemish_1990
Hi Igor,
I have read the suggested document but it nowhere confirming whether it is using hardware scaler(IPU) or ARM (CPU).
Would you please confirm ?
Jemish
1,115件の閲覧回数
