Using the GC320 to adjust brightness, contrast, and hue
sheldonrucker
Hello All,
I'm trying to find a way to adjust the brightness, contrast, and hue of a texture using the GC320 graphic processor on the i.MX6.   Does anyone know if this is possible?  If it is possible could you explain how or give a little example?
I've been reading through the "i.MX 6 2D API" but haven't come upon a solution.
Also, could someone point me at some example code for the 2D GPU API?  I've looked in both LTIB and the Freescale documentation but haven't found anything.
Thank you,
Sheldon
Labels (3)
Tags (2)
sheldonrucker
If I was using the 3D GPU then I could write a fragment shader to adjust the brightness and such.  Does anyone know if there's a similar feature on the 2D GPU?  I.E. some function or the like that allows a multiplication and offset to be applied on a per pixel basis?
Thank you,
Sheldon
sheldonrucker
Anyone have any suggestions?
I've determined how to do this using the i.mx6 CSC matrix but I'd like to be able to do it using the GC320 as well.
Thank you,
Sheldon
YixingKong
Senior Contributor IV
Sheldton
We have not got your response yet and will close the discussion in 3 days. If you still need help, please feel free to reply with an update to this discussion.
Yixing
YixingKong
Sheldton
We are sorry for getting back to you so late. Are you still stuck with the issue? If you have somehow to resolved the issue, can we close the discussion? If you still need help, please feel free to reply with an update to this discussion.
Yixing
