Using the CSI inputs on IMX6DQCEC
1,813 次查看
davidbrooks
I'd like to drive the CSI inputs from a DSI (Display Serial Interface: in effect, serialized BT.565) signal source, but from what I can see, the serial camera inputs only accept proprietary signal standards such as MIPI. Will DSI work, or alternatively, are there any other public serial data standards which CSI can accept?
Regards & TIA
1,507 次查看
weidong_sun
Hello,David,
      There are 3 kinds of camera interface:
(1)CS0 port (parallel interface)
(2)CS1 port (parallel interface)
(3)MIPI port (serial interface)
     In addition, DSI port is display output . Not camera signal input .
Weidong
1,508 次查看
weidong_sun
Hello,David,
Weidong
1,507 次查看
davidbrooks
Many thanks, Weidong.
Those picture make it all clear.
