Using i.mx8mp isi to convert raw10 to raw8
1,210 次查看
454799790
Hi NXP community,
I am using a sensor which can only output mipi raw10 format,but I need a raw8 format.
Can I use the isi to convert raw10 to raw8?
Thanks.
1,168 次查看
454799790
Or can the mipi csi recevier do this?We don't want to convert raw10 to raw8 by cpu,it's too slow.
1,117 次查看
Sanket_Parekh
Hi @454799790 ,
I hope you are doing well.
RAW format input is copied into memory without any pixel change in ISI.
Please refer to 6.3.2 i.MX 8MN/i.MX 8MP ISI configuration in i.MX 8M Series MIPI Capture System for more information.
Thanks & Regards,
Sanket Parekh
