Using cst-tools signing *.out file
1,878 次查看
vijith_g1
I am using sbc connect core 6 board for my product development. I have to add security to my developed firmware application. Because we are planning to use secure update of the application firmware. For that we are planning to use cst-tools signing method. Please let me know using cst-tools can I sign the *.out file and verify in user space. Please let me know any other method ?
I am using Digi yocto build dey 2.4 version.
Thanks & Regards
Vijith G
标签 (4)
1,794 次查看
Yuri
vijith.g@honeywell.com
  I've sent You some comments directly.
Yuri.
1,794 次查看
vijith_g1
I have some queries related to the document you have shared.
Verification and Authentication:
1: csf file where does come from?
2: In the machine authentication perform apart from signed image and srk efuse information is other any items to authenticate?
3: Document mentioned csf file to install certificates, in a machine which is not connected to internet, will this certificate installation happen?
4: Where will be Certifying authority (CA) in the authentication machine?
5: is csf file a signed application file?
1,794 次查看
Yuri
  below are my comments.
1) The CSF file in the document is just an (typical) example.
2) Yes - usually only signed image and the fuses are checked.
3,4) Since root (SRK) is local - no need for I-net.
5) CSF is text file, which will be converted to binary form to be checked by boot ROM.
Yuri.
