Using Uart to serial download image to NOR.
已解决
跳至解决方案
1,574 次查看
primetime
I am developing on QSB using IAR  and JTAG to lload to ram and run the application.  We also tweak  the QSB OBDS to burn the image to NOR  using  JTAG   I  need to be able to serially via uart burn the image to NOR.   Is the MFG TOOL able to do that  via UART.
Looking  for suggestions. Thanks.
标签 (1)
1 解答
1,331 次查看
jimmychan
The MFG Tool only support USB. If you want to use UART, unfortunately we don't have document talk about this. You may need to customize it by yourself.
One option is ATK tool which support UART and USB. But it was a programming tool used for i.MX51, not for i.MX53. I think you can take it as a referene.
IMX_ATK_SOURCE_CODE  (ver. 1.7)
在原帖中查看解决方案
1 回复
1,332 次查看
jimmychan
