Using SCU_GPIO0_01 as a GPIO from A35 on i.MX 8QuadXPlus
已解决
跳至解决方案
535 次查看
wmr-veranex
Is it possible to change the output of SCU_GPIO0_01 from the A35 in Yocto Linux 6.6.y without changing either the SCU or the M40 firmware?
I am working with a hardware design that is already mature and has SCU_GPIO0_01 wired out to other logic circuits that I need to control.
Or, is it possible to change the pinmux function of that pin from Linux userspace?  I have found that switching between the functions SCU_GPIO0_IO01 and M40_UART0_TX by changing device trees and rebooting gives the low and high outputs on that pin that I am seeking, so changing the pinmux from userspace would be another way that I could control that line if changing the drive directly is not an option.
1 解答
507 次查看
JorgeCas
1 回复
508 次查看
JorgeCas
Is needed to modify SCFW to modify IOMUX registers as you can check in:
https://community.nxp.com/t5/i-MX-Processors-Knowledge-Base/System-Controller-Firmware-101-Pad-confi...
I suggest you take a look in the next post:
https://community.nxp.com/t5/i-MX-Processors/How-to-access-SCU-GPIO0-00-from-core-A35-u-boot-or-Linu...
Best regards.
%3CLINGO-SUB%20id%3D%22lingo-sub-2172860%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%B0%86%20SCU_GPIO0_01%20%E7%94%A8%E4%BD%9C%20i.MX%208QuadXPlus%20%E4%B8%8A%20A35%20%E7%9A%84%20GPIO%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2172860%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%98%AF%E5%90%A6%E6%9C%89%E5%8F%AF%E8%83%BD%E5%9C%A8%20Yocto%20Linux%206.6.y%20%E4%B8%AD%E6%9B%B4%E6%94%B9%20A35%20%E7%9A%84%20SCU_GPIO0_01%20%E8%BE%93%E5%87%BA%EF%BC%9F%E6%97%A0%E9%9C%80%E6%9B%B4%E6%94%B9%E8%A7%A3%E7%A0%81%E5%99%A8%E6%88%96%20M40%20%E5%9B%BA%E4%BB%B6%EF%BC%9F%3C%2FP%3E%3CP%3E%E6%88%91%E6%AD%A3%E5%9C%A8%E4%BD%BF%E7%94%A8%E4%B8%80%E4%B8%AA%E5%B7%B2%E7%BB%8F%E6%88%90%E7%86%9F%E7%9A%84%E7%A1%AC%E4%BB%B6%E8%AE%BE%E8%AE%A1%EF%BC%8C%E5%AE%83%E5%B7%B2%E5%B0%86%20SCU_GPIO0_01%20%E4%B8%8E%E6%88%91%E9%9C%80%E8%A6%81%E6%8E%A7%E5%88%B6%E7%9A%84%E5%85%B6%E4%BB%96%E9%80%BB%E8%BE%91%E7%94%B5%E8%B7%AF%E8%BF%9E%E6%8E%A5%E8%B5%B7%E6%9D%A5%E3%80%82%3C%2FP%3E%3CP%3E%E6%88%96%E8%80%85%EF%BC%8C%E8%83%BD%E5%90%A6%E4%BB%8E%20Linux%20%E7%94%A8%E6%88%B7%E7%A9%BA%E9%97%B4%E6%9B%B4%E6%94%B9%E8%AF%A5%E5%BC%95%E8%84%9A%E7%9A%84%20pinmux%20%E5%8A%9F%E8%83%BD%EF%BC%9F%20%E6%88%91%E5%8F%91%E7%8E%B0%EF%BC%8C%E9%80%9A%E8%BF%87%E6%9B%B4%E6%94%B9%E8%AE%BE%E5%A4%87%E6%A0%91%E5%92%8C%E9%87%8D%E5%90%AF%E5%9C%A8%E5%87%BD%E6%95%B0%20SCU_GPIO0_IO01%20%E5%92%8C%20M40_UART0_TX%20%E4%B9%8B%E9%97%B4%E5%88%87%E6%8D%A2%20SCU_GPIO01%20%E5%92%8C%20M40_UART0_TX%20%E5%8F%AF%E4%BB%A5%E5%BE%97%E5%88%B0%E6%88%91%E6%AD%A3%E5%9C%A8%E5%AF%BB%E6%89%BE%E7%9A%84%E8%AF%A5%E5%BC%95%E8%84%9A%E7%9A%84%E4%BD%8E%E8%BE%93%E5%87%BA%E5%92%8C%E9%AB%98%E8%BE%93%E5%87%BA%EF%BC%8C%E5%9B%A0%E6%AD%A4%EF%BC%8C%E5%A6%82%E6%9E%9C%E4%B8%8D%E8%83%BD%E7%9B%B4%E6%8E%A5%E6%9B%B4%E6%94%B9%E9%A9%B1%E5%8A%A8%E5%99%A8%EF%BC%8C%E5%88%99%E4%BB%8E%E7%94%A8%E6%88%B7%E7%A9%BA%E9%97%B4%E6%9B%B4%E6%94%B9%20pinmux%20%E5%B0%86%E6%98%AF%E6%88%91%E5%8F%AF%E4%BB%A5%E6%8E%A7%E5%88%B6%E8%AF%A5%E7%BA%BF%E8%B7%AF%E7%9A%84%E5%8F%A6%E4%B8%80%E7%A7%8D%E6%96%B9%E5%BC%8F%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2172937%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Using%20SCU_GPIO0_01%20as%20a%20GPIO%20from%20A35%20on%20i.MX%208QuadXPlus%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2172937%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3C%2FP%3E%0A%3CP%3E%E9%9C%80%E8%A6%81%E4%BF%AE%E6%94%B9%20SCFW%20%E4%BB%A5%E4%BF%AE%E6%94%B9%20IOMUX%20%E5%AF%84%E5%AD%98%E5%99%A8%EF%BC%8C%E6%82%A8%E5%8F%AF%E4%BB%A5%E5%9C%A8%E8%BF%99%E9%87%8C%E6%9F%A5%E7%9C%8B%EF%BC%9A%3C%2FP%3E%0A%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fi-MX-Processors-Knowledge-Base%2FSystem-Controller-Firmware-101-Pad-configuration-service%2Fta-p%2F1124213%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fi-MX-Processors-Knowledge-Base%2FSystem-Controller-Firmware-101-Pad-configuration-service%2Fta-p%2F1124213%3C%2FA%3E%20%3C%2FP%3E%0A%3CP%3E%E6%88%91%E5%BB%BA%E8%AE%AE%E4%BD%A0%E7%9C%8B%E7%9C%8B%E4%B8%8B%E4%B8%80%E7%AF%87%E6%96%87%E7%AB%A0%EF%BC%9A%3C%2FP%3E%0A%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fi-MX-Processors%2FHow-to-access-SCU-GPIO0-00-from-core-A35-u-boot-or-Linux%2Ftd-p%2F1423541%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fi-MX-Processors%2FHow-to-access-SCU-GPIO0-00-from-core-A35-u-boot-or-Linux%2Ftd-p%2F1423541%3C%2FA%3E%20%3C%2FP%3E%0A%3CP%3E%E9%A1%BA%E7%A5%9D%E5%95%86%E7%A5%BA%EF%BC%81%3C%2FP%3E%3C%2FLINGO-BODY%3E
