User login fails to create /run/user/uid directory
keith_rogers
I installed L4.14.78 on my i.MX 8M Mini evk. I created a normal user account via adduser. When I login to that account I get the following error:
           mkdir: cannot create directory '/run/user/1001': Permission denied
followed by this error:
           chmod: cannot access '/run/user/1001': No such file or directory
The login does get into the shell and such, but I presume a number of applications that need temp storage space will fail because of the missing directory. Root login does not have the problem. Help to fix this would be welcomed.
Labels (2)
garyhubley
Having the same problem. i.MX8M nano. Yocto Zeus.
vincentz63
Same issue. Did you find a solution?
joanxie
what command do you put when you get the wrong message? did you login as root, use like "sudo"?
