Use of ADV# pin in parallel NOR flash (ADMUX) interfacing
VishalAvg
I want to interface parallel NOR flash (256KB*16) with IMXRT1062 but this processor have same port pins for address and data bus. So, I find that ADV#. What is use of this ADV# pin?
I have found this notes for SRAM. Is it same applicable for NOR flash also?
ADV# pin enables Address Path (ADQ=Address Buffer) by asserting ADV# input Low. When ADV# is High, Data Path is enabled (ADQ=I/O Buffer).
Omar_Anguiano
From the SEMC side, the data and address pins will be on MUX mode so it is not possible to have dedicated address/data pins for NOR flash. The communication will look like this:
Regarding using an external component to separate these signals. It looks viable however I cannot confirm if it is your adequate solution since it was not tested on our side.
Omar
VishalAvg
Please reply me!
Omar_Anguiano
Yes, the use of ADV on nor flash is similar to the SRAM.
Omar
VishalAvg
Ok, Thanks for help.
Please tell me one more thing.
How can I interface parallel NOR flash for separate address bus and data bus? Can we interface directly?
If I interface same terminal of imxrt1062 with NOR flash address and data pins then command will be transfered on both bus of parallel NOR flash.
I have attached one image.
I am thinking to add two 74LVC164245 IC in between imxrt1062 and flash chip. So that we can separate address/data transfer to flash chip.
Omar_Anguiano
Omar
VishalAvg
Ok thanks
%3CLINGO-SUB%20id%3D%22lingo-sub-1866213%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EUse%20of%20ADV%23%20pin%20in%20parallel%20NOR%20flash%20(ADMUX)%20interfacing%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1866213%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%2C%3C%2FP%3E%3CP%3EI%20want%20to%20interface%20parallel%20NOR%20flash%20(256KB*16)%20with%20IMXRT1062%20but%20this%20processor%20have%20same%20port%20pins%20for%20address%20and%20data%20bus.%20So%2C%20I%20find%20that%20ADV%23.%20What%20is%20use%20of%20this%20ADV%23%20pin%3F%26nbsp%3B%3C%2FP%3E%3CP%3E%3CSTRONG%3EI%20have%20found%20this%20notes%20for%20SRAM.%20Is%20it%20same%20applicable%20for%20NOR%20flash%20also%3F%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3EADV%23%20pin%20%3C%2FSTRONG%3Eenables%20Address%20Path%20(ADQ%3DAddress%20Buffer)%20by%20asserting%20ADV%23%20input%20Low.%20When%20ADV%23%20is%20High%2C%20Data%20Path%20is%20enabled%20(ADQ%3DI%2FO%20Buffer).%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1880322%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Use%20of%20ADV%23%20pin%20in%20parallel%20NOR%20flash%20(ADMUX)%20interfacing%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1880322%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EOk%20thanks%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1877677%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Use%20of%20ADV%23%20pin%20in%20parallel%20NOR%20flash%20(ADMUX)%20interfacing%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1877677%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EFrom%20the%20SEMC%20side%2C%20the%20data%20and%20address%20pins%20will%20be%20on%20MUX%20mode%20so%20it%20is%20not%20possible%20to%20have%20dedicated%20address%2Fdata%20pins%20for%20NOR%20flash.%20The%20communication%20will%20look%20like%20this%3A%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Omar_Anguiano_0-1717025460922.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Omar_Anguiano_0-1717025460922.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F281608i14EE36C3D48EF8A8%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Omar_Anguiano_0-1717025460922.png%22%20alt%3D%22Omar_Anguiano_0-1717025460922.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3ERegarding%20using%20an%20external%20component%20to%20separate%20these%20signals.%20It%20looks%20viable%20however%20I%20cannot%20confirm%20if%20it%20is%20your%20adequate%20solution%20since%20it%20was%20not%20tested%20on%20our%20side.%3C%2FP%3E%0A%3CP%3EBest%20regards%2C%3CBR%20%2F%3EOmar%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1872175%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Use%20of%20ADV%23%20pin%20in%20parallel%20NOR%20flash%20(ADMUX)%20interfacing%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1872175%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EPlease%20reply%20me!%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1866758%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Use%20of%20ADV%23%20pin%20in%20parallel%20NOR%20flash%20(ADMUX)%20interfacing%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1866758%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EOk%2C%20Thanks%20for%20help.%3C%2FP%3E%3CP%3EPlease%20tell%20me%20one%20more%20thing.%3C%2FP%3E%3CP%3EHow%20can%20I%20interface%20parallel%20NOR%20flash%20for%20separate%20address%20bus%20and%20data%20bus%3F%20Can%20we%20interface%20directly%3F%3C%2FP%3E%3CP%3EIf%20I%20interface%20same%20terminal%20of%20imxrt1062%20with%20NOR%20flash%20address%20and%20data%20pins%20then%20command%20will%20be%20transfered%20on%20both%20bus%20of%20parallel%20NOR%20flash.%3C%2FP%3E%3CP%3EI%20have%20attached%20one%20image.%26nbsp%3B%3C%2FP%3E%3CDIV%3E%3CSPAN%3EI%20am%20thinking%20to%20add%20two%26nbsp%3B74LVC164245%20IC%20in%26nbsp%3Bbetween%20imxrt1062%20and%20flash%20chip.%20So%20that%20we%20can%20separate%20address%2Fdata%20transfer%20to%20flash%20chip.%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1866607%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Use%20of%20ADV%23%20pin%20in%20parallel%20NOR%20flash%20(ADMUX)%20interfacing%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1866607%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EYes%2C%20the%20use%20of%20ADV%20on%20nor%20flash%20is%20similar%20to%20the%20SRAM.%3C%2FP%3E%0A%3CP%3EBest%20regards%2C%3CBR%20%2F%3EOmar%3C%2FP%3E%3C%2FLINGO-BODY%3E
