Hi all,
I have a question about recommendation of PMIC_STBY_REQ when it unused.
I'll not use the function of PMIC_STBY_REQ so I want to know the recommendation.
I can' find any recommendation about it in hardware design guide for i.MX6SL.
https://www.nxp.com/webapp/Download?colCode=IMX6SLHDG
On the other hand, I found a recommendation about it in hardware design guide for i.MX6Q.
It says that If unused, the signal should be left unconnected:
https://www.nxp.com/webapp/Download?colCode=IMX6DQ6SDLHDG
Can i.MX6SL leave it unconnected same as i.MX6Q ?
My concern is those signal type is different.
i.MX6Q is open-drain output.
i.MX6SL is push-pull output.
Ko-hey
Solved! Go to Solution.
Generally unused output pin recommendationscommon for all i.MX procesors :
DIGITAL OR ANALOG OUTPUT RECOMMENDATIONS Leave the unused output pins floating. so just let it free
