Unused DRAM data pins of i.MX 6SoloX
已解决
跳至解决方案
913 次查看
Cyril_R
Hi all,
I am using i.MX 6SoloX processor and only one 256M16 DDR3L. Can i connect this DDR3L chip to DRAM_DATA16-DRAM_DATA31 pins of processor and leave the unused DRAM_DATA00-DRAM_DATA15 pins floating?
Thanks.
1 解答
909 次查看
Rita_Wang
Do not recommend you to use the 16bit ddr3l, recommend you to use the 32bit ddr3l so that the i.MX6SX can reach to the best performance. Here if you still want to use the 16bit ddr3l, use the DRAM_DATA00-DRAM_DATA15 pins, let the DRAM_DATA16-DRAM_DATA31 pins floating.
在原帖中查看解决方案
1 回复
910 次查看
Rita_Wang
