Hello @all, I am working on custom board based on NXP IMX6UL EVK. I am trying to print logo by integrating RP-F10-K27J1 on custom board. I have added cups in my yocto project. Build and flashed the images. When i am trying to print i am getting the following error root@imx6ul-pds:~# lp -d SII_RP-F10_G10 phytec-logo.png lp: Unsupported document-format "image/png". For every image format i am getting unsupported document error for the respective image format. Can you please suggest me the steps on how to add filters in custom board. Please let me know if any Please find the document attached to this ticket.In the document i have shared how to install and configure the printer in custom board. Thanks in Advance Best Regards Shamiullah
解決済! 解決策の投稿を見る。
Hi jimmychan,
The issue got resolved by copying filters from /usr/lib to /usr/libexec directory. Thank you for the respone.
Thanks & Regards,
Shamiullah
I think you may check if there is cups's library(for ARM) or source code of the filter for png. Then modify the .bb file in yocto to build/install the library to your image. Or using the ARM toolchain compiler to compile the source code and then put the built library file to your board root filesystem.
Hello jimmychan,
Thank you for your valuable response.
I have added filters by including cups-filters source in yocto and check the filters in the respective path and it is included in root file system. But again i am getting the same problem. Please let me know if any
With Regards
Shamiullah
I hope this link useful for you
http://etutorials.org/Linux+systems/how+linux+works/Chapter+12+Printing/12.5+CUPS/
Hi jimmychan,
Thanks & Regards,
Shamiullah
