Unknown values at the start of i.MX 8MM EVK's QSPI imx-boot
kanimozhi_t
Hi Team,
In i.MX 8M Mini EVK, we've generated the QSPI image by adding the configuration “UBOOT_CONFIG= fspi" in "local.conf" file.
As normal, the QSPI image address is started after 0x1000 address but in our image initial address having some (constant) value. The values shown in below screenshot:
1. Is this initial value normal?
2. If so, what are those?
3. If not, how can we remove/clean that?
Thanks in advance.
