Hi, Community
I am reading "i.MX 7Dual Applications Processor Reference Manual".
There is the following description on page 1237.
6.6.6.4 IOMUX configuration for QSPI devices
The QSPI interface uses the dedicated contacts on the IC. The contacts assigned to the
data signals used by the QSPI are shown in these tables:
What does "these tables" indicate?
Yuichi Takeda
Solved! Go to Solution.
This seems to be an error on the reference manual, please take a look to section 10.2.2 External Signals which describe the QSPI pins, sorry for the confusion.
Thank you,
Aldo.
Thank you,
Aldo.
Hi Aldo,
Thank you for your reply!
I understand.
I will refer to the section.
Yuichi Takeda
