Unknown description in "i.MX 7Dual Applications Processor Reference Manual"
1,365 次查看
yuichi_takeda
Hi, Community
I am reading "i.MX 7Dual Applications Processor Reference Manual".
There is the following description on page 1237.
6.6.6.4 IOMUX configuration for QSPI devices
The QSPI interface uses the dedicated contacts on the IC. The contacts assigned to the
data signals used by the QSPI are shown in these tables:
What does "these tables" indicate?
Yuichi Takeda
1,294 次查看
AldoG
This seems to be an error on the reference manual, please take a look to section 10.2.2 External Signals which describe the QSPI pins, sorry for the confusion.
Thank you,
Aldo.
1,295 次查看
AldoG
Thank you,
Aldo.
1,294 次查看
yuichi_takeda
Hi Aldo,
Thank you for your reply!
I understand.
I will refer to the section.
Yuichi Takeda
