Unable to play videos through qtmultimedia using gstreamer-1.0 for imx6 by yocto build image. Showing No m_videoSink available!
madhureddy
Hello All,
I am unable to play videos through qtmultimedia gstreamer-1.0 for imx6.
meta-qt5: dizzy
from HMI, i am trying to play video, it showing the below message.
root@nitrogen6x:~# ./HMI_IVI_APP_2.2/HMI_IVI_APP/HMI_IVI_APP --platform eglfs &
[1] 318
root@nitrogen6x:~# QEglFSImx6Hooks will set environment variable FB_MULTI_BUFFER=2 to enable double buffering and vsync.
If this is not desired, you can override this via: export QT_EGLFS_IMX6_NO_FB_MULTI_BUFFER=1
Unable to query physical screen size, defaulting to 100 dpi.
To override, set QT_QPA_EGLFS_PHYSICAL_WIDTH and QT_QPA_EGLFS_PHYSICAL_HEIGHT (in millimeters).
libpng warning: iCCP: known incorrect sRGB profile
qml: disabling the mouse area
qml: @ normal screen
qml: From JS file To 1
qml: Current index = 1
qml: enabling the mouse area
qml: 3
qml: [file:///home/root/HMI_IVI_APP_2.2/HMI_IVI_APP/C++ Qt 40 - QMap.mp4]
qml: @ Before loading Global.filename file:///home/root/HMI_IVI_APP_2.2/HMI_IVI_APP/C++ Qt 40 - QMap.mp4
Could not resolve property : Polkadots-largewhite
qml: @ full screen
====== AIUR: 4.0.3 build on Jan 20 2016 23:33:57. ======
Core: MPEG4PARSER_06.09.00 build on Apr 16 2014 02:20:23
file: /usr/lib/imx-mm/parser/lib_mp4_parser_arm11_elinux.so.3.2
[1]+ Done(1) ./HMI_IVI_APP_2.2/HMI_IVI_APP/HMI_IVI_APP --platform eglfs
Original Attachment has been moved to: m_videoSink_not_available_log.txt.zip
Hi Madhu
please try demo applications (only available in platforms that have
hardware video codec) on X11 as described in sect.6.4 "Freescale Qt
Applications"  attached Release Notes. Below NXP BSP
Board Support Packages (32)
L3.14.52_1.1.0_MX6QDLSOLO (REV L3.14.52_1.1.0)
http://www.nxp.com/products/microcontrollers-and-processors/arm-processors/i.mx-applications-process...
regarding nitrogen6x BSPs please post on meta-fsl-arm mailing list,
so that someone familiar with these boards could try to assist you.
https://lists.yoctoproject.org/listinfo/meta-freescale
madhureddy
Hi igorpadykov,
Thanks for your answer.
But I am working for nitrogen6x board.
through qtgstreamer on wayland trying to play videos, showing the below message.
[1] 318
qml: 3
qml: @ full screen
gary_bisson
Senior Contributor III
Hi Madhu,
I looks like the QtMultimedia component doesn't really take eglfs into account:
[Development]  The dark side of QtMultimedia - strikes back
Maybe you can try modifying the component to force the use of the video sink of your choice.
Also, another test would be to make sure a camerabin pipeline works fine:
$  gst-launch-1.0 camerabin
Gary
Hi Madhu
please try nxp release with sabre reference board,
