Unable to give Keyboard input for IMX8QM-MEK
1,561 次查看
LokeshGandham
I have downloaded the pre-built Linux image from here  and flashed the SD card with
sudo dd if=imx-image-full-imx8qmmek.wic of=/dev/sdc bs=1M && sync
 I was able to see imx8qmmek login prompt in minicom terminal but unable to give any keyboard input for logging in. attached the screenshot and bootup logs.
1 回复
1,542 次查看
Chavira
Hi @LokeshGandham!
Thank you for contacting NXP Support!
Try to run minicom with sudo.
If the problem persists, try to use "screen" instead of minicom, and change the USB debug cable if necessary.
The board is booting correctly, I think is a Host issue.
Best Regards!
Chavira
