Unable to generate dtb for imx35pdk
934 次查看
ashwatd
I am trying to build a kernel for the imx35 pdk board using the yocto build system. I am able to generate a kernel image but i am not able to find any dtb files generated for the board. The kernel configuration has the support for device tree configuration enabled. What am i missing here?
标签 (1)
2 回复数
827 次查看
ashwatd
Thanks for your response Fabio. Will check the meta-fsl-arm mailing list.
827 次查看
fabio_estevam
The dts for this board is available at: arch/arm/boot/dts/imx35-pdk.dts
imx35pdk is not supported in Yocto yet. Maybe you can add support for this board to meta-fsl-arm mailing list.
