Unable to export NXP_PROD_KA_PUB on imx93
2,386件の閲覧回数
JonhDoe
Following the response I got from this forum question  here , this seems to be the thing we are looking for. However, we are unable to export NXP_PROD_KA_PUB key at id 0x70000000.
We tried from the linux userspace with the nvm_daemon, which starts correctly but fails when trying to export it when sending the ELE message.
We also tried from U-Boot and spdsk and the problem still persists :
user@vbox:/data/gitclone/src_spsdk/spsdk$ uv run spsdk nxpele -f mimx9352 -p /dev/ttyACM0 -d uboot_serial export-nxp-prod-ka-puk -o file
Step 1/4: Initializing SAB...
SAB Init successful
Step 2/4: Opening session...
Session opened successfully. Handle: 0xE59B04F0
Step 3/4: Opening keystore...
Keystore opened successfully. Handle: 0xE59B0970
Step 4/4: Exporting public key...
Error during NXP Production Key Agreement Public Key export: SPSDK: ELE Message failed.
Command: PUBLIC_KEY_EXPORT_REQ - (0x32)
Command words: 7
Command data: False
Response words: 4
Response data: True
Response status: Failure
Response indication: ResponseIndication:Unknown_0x1b - (0x1b)
Response abort code: 0x0
Public Key Export Command:
- Key store handle: 0xE59B0970
- Key ID: 0x70000000
- Output buffer size: 64 bytes
- Exports public key of asymmetric key from key store
- Public key is re-calculated (except Twisted Edwards/Montgomery)
- Must be called after opening valid key store service
Key ID: 0x70000000
Output public key size: 0 bytes
No public key data received
Cleaning up: Closing keystore...
Cleaning up: Closing session...
Failed to export NXP Production Key Agreement Public Key
And everything seems correct from get-info, SRKH is fused and from my knowledge the device does not needs to be OEM closed to export it. Below is the content of get-info :
user@vbox:/data/gitclone/src_spsdk/spsdk$ uv run spsdk nxpele -f mimx9352 -p /dev/ttyACM0 -d uboot_serial get-info
ELE get info ends successfully:
Command: 0xda
Version: 2
Length: 160
SoC ID: MX93 - 0x9300
SoC version: A100
Life Cycle: OEM_OPEN - 0x0010
SSSM state: 4
Attest API version: 2
UUID: 86ee42794bb64887bddcb53e5666e040
SHA256 ROM PATCH: e9b0338e5f4a0a92025f764c5eeae2d26be1211c77ee51e49a9ee36a7185d587
SHA256 FW: 7d0dd0b6d993e4df39eb69cee18b4f7eb6ac1622aaf7d144c25c00cc4908ca60
Advanced information:
OEM SRKH: 2a6b7811117a8f2d16e1b506b587f6f44e2e444111f8ec7df047eec5200e6fd9
IMEM state: The IMEM is fully loaded and all ELE functionality can be used - 0xCA
CSAL state: EdgeLock secure enclave random context initialization succeed - 0x02
TRNG state: TRNG entropy is valid and ready to be read - 0x03
Thanks in advance for your response.
2,299件の閲覧回数
JonhDoe
Hello again,
I just needed to update the ELE fw, I mark this as solved.
Thanks for your time.
タグ(1)
3 返答(返信)
2,312件の閲覧回数
Harvey021
Which version of BSP and ELE FW are you using?
Harvey
2,308件の閲覧回数
JonhDoe
Hello Harvey,
We are using lf-6.12-y for linux, lf_2024.07 for u-boot and here is the output of "get-ele-fw-version":
(spsdk) eliott@vbox:/data/gitclone/src_spsdk/spsdk$ uv run nxpele -f mimx9352 -p /dev/ttyUSB0 -d uboot_serial get-ele-fw-version
Get ELE firmware version ends successfully:
EdgeLock Enclave firmware version: 0800000B
Readable form: 0.0.11
Commit SHA1 (First 4 bytes): 33CDA99A
John
2,300件の閲覧回数
JonhDoe
Hello again,
タグ(1)
%3CLINGO-SUB%20id%3D%22lingo-sub-2232723%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3Eimx93%20%E3%81%A7%20NXP_PROD_KA_PUB%20%E3%82%92%E3%82%A8%E3%82%AF%E3%82%B9%E3%83%9D%E3%83%BC%E3%83%88%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2232723%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%3C%2FP%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fi-MX-Processors%2Fquot-Fleet-certificate-quot-on-imx93%2Fm-p%2F2205862%2Femcs_t%2FS2h8ZW1haWx8YWNjZXB0X2FzX3NvbHV0aW9uX3JlbWluZGVyfE1JODMyVzFGRUIzWU9BfDIyMDU4NjJ8T1RIRVJTfGhL%23M242210%20%22%20target%3D%22_self%22%3E%E3%81%93%E3%81%93%E3%81%A7%E3%81%AE%3C%2FA%3E%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A9%E3%83%A0%E3%81%AE%E8%B3%AA%E5%95%8F%E3%81%AB%E5%AF%BE%E3%81%97%E3%81%A6%E5%BE%97%E3%81%9F%E5%9B%9E%E7%AD%94%E3%81%AB%E3%82%88%E3%82%8C%E3%81%B0%E3%80%81%E3%81%93%E3%82%8C%E3%81%8C%E7%A7%81%E3%81%9F%E3%81%A1%E3%81%8C%E6%8E%A2%E3%81%97%E3%81%A6%E3%81%84%E3%81%9F%E3%82%82%E3%81%AE%E3%81%AE%E3%82%88%E3%81%86%E3%81%A7%E3%81%99%E3%80%82%E3%81%9F%E3%81%A0%E3%81%97%E3%80%81ID%200x70000000%20%E3%81%AE%20NXP_PROD_KA_PUB%20%E3%82%AD%E3%83%BC%E3%82%92%E3%82%A8%E3%82%AF%E3%82%B9%E3%83%9D%E3%83%BC%E3%83%88%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3CP%3Envm_daemon%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%20Linux%20%E3%83%A6%E3%83%BC%E3%82%B6%E3%83%BC%E7%A9%BA%E9%96%93%E3%81%8B%E3%82%89%E8%A9%A6%E3%81%97%E3%81%A6%E3%81%BF%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81%E6%AD%A3%E5%B8%B8%E3%81%AB%E8%B5%B7%E5%8B%95%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81ELE%20%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E3%82%92%E9%80%81%E4%BF%A1%E3%81%99%E3%82%8B%E3%81%A8%E3%81%8D%E3%81%AB%E3%82%A8%E3%82%AF%E3%82%B9%E3%83%9D%E3%83%BC%E3%83%88%E3%81%97%E3%82%88%E3%81%86%E3%81%A8%E3%81%99%E3%82%8B%E3%81%A8%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3EU-Boot%20%E3%81%A8%20spdsk%20%E3%81%8B%E3%82%89%E3%82%82%E8%A9%A6%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81%E5%95%8F%E9%A1%8C%E3%81%AF%E4%BE%9D%E7%84%B6%E3%81%A8%E3%81%97%E3%81%A6%E8%A7%A3%E6%B1%BA%E3%81%97%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3CP%3Euser%40vbox%3A%2Fdata%2Fgitclone%2Fsrc_spsdk%2Fspsdk%24%20uv%20run%20spsdk%20nxpele%20-f%20mimx9352%20-p%20%2Fdev%2FttyACM0%20-d%20uboot_serial%20export-nxp-prod-ka-puk%20-o%20file%3CBR%20%2F%3E%E3%82%B9%E3%83%86%E3%83%83%E3%83%97%201%2F4%3A%20SAB%20%E3%82%92%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99...%3CBR%20%2F%3E%20SAB%E5%88%9D%E6%9C%9F%E5%8C%96%E6%88%90%E5%8A%9F%3CBR%20%2F%3E%E3%82%B9%E3%83%86%E3%83%83%E3%83%97%202%2F4%3A%20%E3%82%BB%E3%83%83%E3%82%B7%E3%83%A7%E3%83%B3%E3%82%92%E9%96%8B%E5%A7%8B%E3%81%97%E3%81%BE%E3%81%99...%3CBR%20%2F%3E%E3%82%BB%E3%83%83%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%8C%E6%AD%A3%E5%B8%B8%E3%81%AB%E9%96%8B%E5%A7%8B%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%83%8F%E3%83%B3%E3%83%89%E3%83%AB%3A%200xE59B04F0%3CBR%20%2F%3E%E3%82%B9%E3%83%86%E3%83%83%E3%83%97%203%2F4%3A%20%E3%82%AD%E3%83%BC%E3%82%B9%E3%83%88%E3%82%A2%E3%82%92%E9%96%8B%E3%81%84%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99...%3CBR%20%2F%3E%E3%82%AD%E3%83%BC%E3%82%B9%E3%83%88%E3%82%A2%E3%81%8C%E6%AD%A3%E5%B8%B8%E3%81%AB%E9%96%8B%E3%81%8B%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%83%8F%E3%83%B3%E3%83%89%E3%83%AB%3A%200xE59B0970%3CBR%20%2F%3E%E3%82%B9%E3%83%86%E3%83%83%E3%83%97%204%2F4%3A%20%E5%85%AC%E9%96%8B%E3%82%AD%E3%83%BC%E3%82%92%E3%82%A8%E3%82%AF%E3%82%B9%E3%83%9D%E3%83%BC%E3%83%88%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99...%3CBR%20%2F%3E%20NXP%20%E3%83%97%E3%83%AD%E3%83%80%E3%82%AF%E3%82%B7%E3%83%A7%E3%83%B3%20%E3%82%AD%E3%83%BC%20%E3%82%A2%E3%82%B0%E3%83%AA%E3%83%BC%E3%83%A1%E3%83%B3%E3%83%88%E5%85%AC%E9%96%8B%E3%82%AD%E3%83%BC%E3%81%AE%E3%82%A8%E3%82%AF%E3%82%B9%E3%83%9D%E3%83%BC%E3%83%88%E4%B8%AD%E3%81%AB%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3A%20SPSDK%3A%20ELE%20%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E3%81%8C%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3CBR%20%2F%3E%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%3A%20PUBLIC_KEY_EXPORT_REQ%20-%20(0x32)%3CBR%20%2F%3E%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%83%AF%E3%83%BC%E3%83%89%3A%207%3CBR%20%2F%3E%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%83%87%E3%83%BC%E3%82%BF%3A%20False%3CBR%20%2F%3E%E5%BF%9C%E7%AD%94%E8%AA%9E%3A%204%3CBR%20%2F%3E%E5%BF%9C%E7%AD%94%E3%83%87%E3%83%BC%E3%82%BF%3A%20True%3CBR%20%2F%3E%E5%BF%9C%E7%AD%94%E3%82%B9%E3%83%86%E3%83%BC%E3%82%BF%E3%82%B9%3A%20%E5%A4%B1%E6%95%97%3CBR%20%2F%3E%E5%BF%9C%E7%AD%94%E8%A1%A8%E7%A4%BA%3A%20ResponseIndication%3AUnknown_0x1b%20-%20(0x1b)%3CBR%20%2F%3E%E5%BF%9C%E7%AD%94%E4%B8%AD%E6%AD%A2%E3%82%B3%E3%83%BC%E3%83%89%3A%200x0%3C%2FP%3E%3CP%3E%E5%85%AC%E9%96%8B%E9%8D%B5%E3%82%A8%E3%82%AF%E3%82%B9%E3%83%9D%E3%83%BC%E3%83%88%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%3A%3CBR%20%2F%3E%20-%20%E3%82%AD%E3%83%BC%E3%82%B9%E3%83%88%E3%82%A2%E3%83%8F%E3%83%B3%E3%83%89%E3%83%AB%3A%200xE59B0970%3CBR%20%2F%3E%20-%20%E3%82%AD%E3%83%BCID%3A%200x70000000%3CBR%20%2F%3E%20-%20%E5%87%BA%E5%8A%9B%E3%83%90%E3%83%83%E3%83%95%E3%82%A1%E3%82%B5%E3%82%A4%E3%82%BA%3A%2064%E3%83%90%E3%82%A4%E3%83%88%3CBR%20%2F%3E-%20%E3%82%AD%E3%83%BC%E3%82%B9%E3%83%88%E3%82%A2%E3%81%8B%E3%82%89%E9%9D%9E%E5%AF%BE%E7%A7%B0%E3%82%AD%E3%83%BC%E3%81%AE%E5%85%AC%E9%96%8B%E3%82%AD%E3%83%BC%E3%82%92%E3%82%A8%E3%82%AF%E3%82%B9%E3%83%9D%E3%83%BC%E3%83%88%E3%81%99%E3%82%8B%3CBR%20%2F%3E-%20%E5%85%AC%E9%96%8B%E9%8D%B5%E3%81%8C%E5%86%8D%E8%A8%88%E7%AE%97%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%EF%BC%88Twisted%20Edwards%2FMontgomery%E3%82%92%E9%99%A4%E3%81%8F%EF%BC%89%3CBR%20%2F%3E%20-%20%E6%9C%89%E5%8A%B9%E3%81%AA%E3%82%AD%E3%83%BC%E3%82%B9%E3%83%88%E3%82%A2%E3%82%B5%E3%83%BC%E3%83%93%E3%82%B9%E3%82%92%E9%96%8B%E3%81%84%E3%81%9F%E5%BE%8C%E3%81%AB%E5%91%BC%E3%81%B3%E5%87%BA%E3%81%99%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3E%E3%82%AD%E3%83%BC%E3%82%B9%E3%83%88%E3%82%A2%E3%83%8F%E3%83%B3%E3%83%89%E3%83%AB%3A%200xE59B0970%3CBR%20%2F%3E%E3%82%AD%E3%83%BCID%3A%200x70000000%3CBR%20%2F%3E%E5%87%BA%E5%8A%9B%E5%85%AC%E9%96%8B%E9%8D%B5%E3%81%AE%E3%82%B5%E3%82%A4%E3%82%BA%3A%200%20%E3%83%90%E3%82%A4%E3%83%88%3CBR%20%2F%3E%E5%85%AC%E9%96%8B%E9%8D%B5%E3%83%87%E3%83%BC%E3%82%BF%E3%81%8C%E5%8F%97%E4%BF%A1%E3%81%95%E3%82%8C%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3E%E3%82%AF%E3%83%AA%E3%83%BC%E3%83%B3%E3%82%A2%E3%83%83%E3%83%97%E4%B8%AD%3A%20%E3%82%AD%E3%83%BC%E3%82%B9%E3%83%88%E3%82%A2%E3%82%92%E9%96%89%E3%81%98%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99...%3CBR%20%2F%3E%E3%82%AF%E3%83%AA%E3%83%BC%E3%83%B3%E3%82%A2%E3%83%83%E3%83%97%3A%20%E3%82%BB%E3%83%83%E3%82%B7%E3%83%A7%E3%83%B3%E3%82%92%E7%B5%82%E4%BA%86%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99...%3CBR%20%2F%3E%20NXP%20Production%20Key%20Agreement%20%E5%85%AC%E9%96%8B%E9%8D%B5%E3%81%AE%E3%82%A8%E3%82%AF%E3%82%B9%E3%83%9D%E3%83%BC%E3%83%88%E3%81%AB%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3E%3CBR%20%2F%3E%E3%81%BE%E3%81%9F%E3%80%81get-info%20%E3%81%8B%E3%82%89%E3%81%AF%E3%81%99%E3%81%B9%E3%81%A6%E6%AD%A3%E3%81%97%E3%81%84%E3%82%88%E3%81%86%E3%81%A7%E3%81%99%E3%80%82SRKH%20%E3%81%AF%E8%9E%8D%E5%90%88%E3%81%95%E3%82%8C%E3%81%A6%E3%81%8A%E3%82%8A%E3%80%81%E7%A7%81%E3%81%AE%E7%9F%A5%E3%82%8B%E9%99%90%E3%82%8A%E3%80%81%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%82%92%E3%82%A8%E3%82%AF%E3%82%B9%E3%83%9D%E3%83%BC%E3%83%88%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AB%20OEM%20%E3%82%AF%E3%83%AD%E3%83%BC%E3%82%BA%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E4%BB%A5%E4%B8%8B%E3%81%AF%20get-info%20%E3%81%AE%E5%86%85%E5%AE%B9%E3%81%A7%E3%81%99%3A%3C%2FP%3E%3CP%3Euser%40vbox%3A%2Fdata%2Fgitclone%2Fsrc_spsdk%2Fspsdk%24%20uv%20run%20spsdk%20nxpele%20-f%20mimx9352%20-p%20%2Fdev%2FttyACM0%20-d%20uboot_serial%20get-info%3CBR%20%2F%3E%20ELE%20%E6%83%85%E5%A0%B1%E5%8F%96%E5%BE%97%E3%81%8C%E6%AD%A3%E5%B8%B8%E3%81%AB%E7%B5%82%E4%BA%86%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3A%3CBR%20%2F%3E%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%3A%200xda%3CBR%20%2F%3E%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%3A%202%3CBR%20%2F%3E%E9%95%B7%E3%81%95%3A%20160%3CBR%20%2F%3E%20SoC%20ID%3A%20MX93%20-%200x9300%3CBR%20%2F%3E%20SoC%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%3A%20A100%3CBR%20%2F%3E%E3%83%A9%E3%82%A4%E3%83%95%E3%82%B5%E3%82%A4%E3%82%AF%E3%83%AB%3A%20OEM_OPEN%20-%200x0010%3CBR%20%2F%3E%20SSSM%E7%8A%B6%E6%85%8B%3A%204%3CBR%20%2F%3E%E8%A8%BC%E6%98%8E%20API%20%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%3A%202%3CBR%20%2F%3E%20UUID%3A%2086ee42794bb64887bddcb53e5666e040%3CBR%20%2F%3E%20SHA256%20ROM%E3%83%91%E3%83%83%E3%83%81%3A%20e9b0338e5f4a0a92025f764c5eeae2d26be1211c77ee51e49a9ee36a7185d587%3CBR%20%2F%3E%20SHA256%20%E3%83%95%E3%82%A1%E3%83%BC%E3%83%A0%E3%82%A6%E3%82%A7%E3%82%A2%3A%207d0dd0b6d993e4df39eb69cee18b4f7eb6ac1622aaf7d144c25c00cc4908ca60%3CBR%20%2F%3E%E8%A9%B3%E7%B4%B0%E6%83%85%E5%A0%B1%3A%3CBR%20%2F%3E%20OEM%20SRKH%3A%202a6b7811117a8f2d16e1b506b587f6f44e2e444111f8ec7df047eec5200e6fd9%3CBR%20%2F%3E%20IMEM%E3%81%AE%E7%8A%B6%E6%85%8B%3A%20IMEM%E3%81%8C%E5%AE%8C%E5%85%A8%E3%81%AB%E3%83%AD%E3%83%BC%E3%83%89%E3%81%95%E3%82%8C%E3%81%A6%E3%81%8A%E3%82%8A%E3%80%81%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AEELE%E6%A9%9F%E8%83%BD%E3%81%8C%E4%BD%BF%E7%94%A8%E5%8F%AF%E8%83%BD%20-%200xCA%3CBR%20%2F%3E%20CSAL%E7%8A%B6%E6%85%8B%3A%20EdgeLock%E3%82%BB%E3%82%AD%E3%83%A5%E3%82%A2%E3%83%BB%E3%82%A8%E3%83%B3%E3%82%AF%E3%83%AC%E3%83%BC%E3%83%96%20%E3%83%A9%E3%83%B3%E3%83%80%E3%83%A0%E3%82%B3%E3%83%B3%E3%83%86%E3%82%AD%E3%82%B9%E3%83%88%E5%88%9D%E6%9C%9F%E5%8C%96%E6%88%90%E5%8A%9F%20-%200x02%3CBR%20%2F%3E%20TRNG%E7%8A%B6%E6%85%8B%3A%20TRNG%E3%82%A8%E3%83%B3%E3%83%88%E3%83%AD%E3%83%94%E3%83%BC%E3%81%AF%E6%9C%89%E5%8A%B9%E3%81%A7%E3%81%82%E3%82%8A%E3%80%81%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%E6%BA%96%E5%82%99%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%20-%200x03%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E3%81%94%E8%BF%94%E4%BF%A1%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E
