Unable to build rtos application with Android Automotive
2,777 次查看
vinothkumars
Senior Contributor IV
Hi All,
Unable to build hello world application for Android 9 Automotive got following error,
Configure hellow world in device-fsl. While building I got following error,
make[1]: *** No rule to make target 'm4_image.bin', needed by 'flash_all_spl_container_ddr_car'. Stop.
Vinothkumar Sekar
2,734 次查看
vinothkumars
I able to build standalone application by modifying the device-fsl.
Vinothkumar Sekar
2,735 次查看
vinothkumars
Vinothkumar Sekar
2,755 次查看
AldoG
to build an M4 rtos application you may do it using GCC Arm or IAR.
When compiled using any of these two toolchains you may use the M4 binary to create the flash.bin
Aldo.
