Unable to build meta-robot-platform
187 次查看
stevelarche
Hello
I followed the vSLAM Yocto build instructions from the following document:
[https://www.nxp.com/docs/en/application-note/AN14240.pdf]
However, the build fails with the following error message:
ERROR: fastrtps-native-2.9.1-4-r0 do_fetch: Fetcher failure: Unable to find revision 24c6b48d4541230c205b5d932a5830be9727cc34 in branch release/rolling/fastrtps even from upstream
ERROR: fastrtps-native-2.9.1-4-r0 do_fetch: Bitbake Fetcher Error: FetchError('Unable to fetch URL from any source.', 'git://github.com/ros2-gbp/fastrtps-release;branch=release/rolling/fastrtps;protocol=https')
ERROR: Logfile of failure stored in: /Work/vSLAM/imx-yocto-bsp/imx8mp-ai-robot-humble/tmp/work/x86_64-linux/fastrtps-native/2.9.1-4-r0/temp/log.do_fetch.132923
ERROR: Task (virtual:native:/Work/vSLAM/imx-yocto-bsp/sources/meta-robot-platform/imx/meta-ros/meta-ros2-humble/generated-recipes/fastrtps/fastrtps_2.9.1-4.bb:do_fetch) failed with exit code '1'
WARNING: fastrtps-2.9.1-4-r0 do_fetch: Failed to fetch URL git://github.com/ros2-gbp/fastrtps-release;branch=release/rolling/fastrtps;protocol=https, attempting MIRRORS if available
ERROR: fastrtps-2.9.1-4-r0 do_fetch: Fetcher failure: Unable to find revision 24c6b48d4541230c205b5d932a5830be9727cc34 in branch release/rolling/fastrtps even from upstream
ERROR: fastrtps-2.9.1-4-r0 do_fetch: Bitbake Fetcher Error: FetchError('Unable to fetch URL from any source.', 'git://github.com/ros2-gbp/fastrtps-release;branch=release/rolling/fastrtps;protocol=https')
ERROR: Logfile of failure stored in: /Work/vSLAM/imx-yocto-bsp/imx8mp-ai-robot-humble/tmp/work/armv8a-poky-linux/fastrtps/2.9.1-4-r0/temp/log.do_fetch.176255
ERROR: Task (/Work/vSLAM/imx-yocto-bsp/sources/meta-robot-platform/imx/meta-ros/meta-ros2-humble/generated-recipes/fastrtps/fastrtps_2.9.1-4.bb:do_fetch) failed with exit code '1'
NOTE: Tasks Summary: Attempted 1123 tasks of which 0 didn't need to be rerun and 2 failed.
Summary: 2 tasks failed:
Summary: There were 25 WARNING messages.
Summary: There were 4 ERROR messages, returning a non-zero exit code.
I found a few community posts from people experiencing the same issue, but none of them included a working solution.
Does anyone know what needs to be modified or fixed to resolve this?
I am attaching the log file as well.
标记 (1)
3 回复数
162 次查看
Zhiming_Liu
Hi @stevelarche
Can you share commands of your building setup?
Zhiming
153 次查看
stevelarche
Hello
I followed the instructions exactly as described in the AN14240 document.
Among the three ROS versions suggested in the document, I selected ROS Humble.
The following are the commands I executed, which are identical to those in AN14240.
$ mkdir imx-yocto-bsp
$ cd imx-yocto-bsp
$ repo init -u https://github.com/nxp-imx/imx-manifest -b imx-linux-kirkstone -m imx-5.15.71-2.2.0.xml
$ repo sync
$ git clone -b imx-aibot-release_v3.3 https://github.com/nxp-imx-support/meta-robot-platform.git
$ cp -dpR meta-robot-platform sources
$ ln -s sources/meta-robot-platform/imx/meta-robot/tools/setup-imx-robot.sh setup-imx-robot.sh
$ DISTRO=imx-robot-xwayland MACHINE=imx8mp-ai-robot source setup-imx-robot.sh -r humble -b imx8mp-ai-robot-humble
$ bitbake imx-robot-sdk
From what I found, fastrtps has been renamed to FastDDS, and it seems that the Git URLs and other related components have changed.
I tried modifying the recipe manually, but doing so caused several other issues during the build.
For cracklib_2.9.8, the build fails because the branch name has changed from master to main.
For OpenSSL 3.1.0, the patch cannot be applied and several hunks fail during the do_patch step.
ERROR: openssl-3.1.0.imx-r0 do_patch: Applying patch '0001-Enhance-cryptodev-s-engine-by-CAAM-public-key-crypto.patch' on target directory '/Work/vSLAM/imx-yocto-bsp/imx8mp-ai-robot-humble/tmp/work/armv8a-poky-linux/openssl/3.1.0.imx-r0/openssl-3.1.0.imx' CmdError('quilt --quiltrc /Work/vSLAM/imx-yocto-bsp/imx8mp-ai-robot-humble/tmp/work/armv8a-poky-linux/openssl/3.1.0.imx-r0/recipe-sysroot-native/etc/quiltrc push', 0, 'stdout: Applying patch 0001-Enhance-cryptodev-s-engine-by-CAAM-public-key-crypto.patch patching file apps/speed.c
patching file crypto/ec/ec_curve.c
patching file crypto/ec/ec_key.c
patching file crypto/ec/ec_local.h
patching file crypto/sm2/sm2_crypt.c
patching file crypto/sm2/sm2_sign.c
patching file engines/e_devcrypto.c
Hunk #10 FAILED at 747.
unk #11 FAILED at 774.
Hunk #12 succeeded at 808 (offset -14 lines).
It can be seen that following the environment setup exactly according to the AN14240 guide leads to issues.
Please take a look and advise.
144 次查看
Zhiming_Liu
Hi @stevelarche
Please refer this case for openssl patch issue.
Zhiming
%3CLINGO-SUB%20id%3D%22lingo-sub-2246816%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A0%E6%B3%95%E7%89%88%E6%9C%AC%E5%85%83%E6%9C%BA%E5%99%A8%E4%BA%BA%E5%B9%B3%E5%8F%B0%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2246816%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%3C%2FP%3E%3CP%3E%3CBR%20%2F%3E%E6%88%91%E6%8C%89%E7%85%A7%E4%BB%A5%E4%B8%8B%E6%96%87%E6%A1%A3%E4%B8%AD%E7%9A%84%20vSLAM%20Yocto%3CBR%20%2F%3E%20%E7%89%88%E6%9C%AC%E8%AF%B4%E6%98%8E%E8%BF%9B%E8%A1%8C%E6%93%8D%E4%BD%9C%EF%BC%9A%5B%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fapplication-note%2FAN14240.pdf%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3E%20https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fapplication-note%2FAN14240.pdf%5D%3C%2FA%3E%3C%2FP%3E%3CP%3E%E4%BD%86%E6%98%AF%EF%BC%8C%E7%89%88%E6%9C%AC%E5%A4%B1%E8%B4%A5%E5%B9%B6%E6%98%BE%E7%A4%BA%E4%BB%A5%E4%B8%8B%E9%94%99%E8%AF%AF%E6%B6%88%E6%81%AF%EF%BC%9A%3C%2FP%3E%3CBLOCKQUOTE%3E%3CPRE%20translate%3D%22no%22%3EERROR%3A%20fastrtps-native-2.9.1-4-r0%20do_fetch%3A%20Fetcher%20failure%3A%20Unable%20to%20find%20revision%2024c6b48d4541230c205b5d932a5830be9727cc34%20in%20branch%20release%2Frolling%2Ffastrtps%20even%20from%20upstream%3CBR%20%2F%3EERROR%3A%20fastrtps-native-2.9.1-4-r0%20do_fetch%3A%20Bitbake%20Fetcher%20Error%3A%20FetchError('Unable%20to%20fetch%20URL%20from%20any%20source.'%2C%20'git%3A%2F%2Fgithub.com%2Fros2-gbp%2Ffastrtps-release%3Bbranch%3Drelease%2Frolling%2Ffastrtps%3Bprotocol%3Dhttps')%3CBR%20%2F%3EERROR%3A%20Logfile%20of%20failure%20stored%20in%3A%20%2FWork%2FvSLAM%2Fimx-yocto-bsp%2Fimx8mp-ai-robot-humble%2Ftmp%2Fwork%2Fx86_64-linux%2Ffastrtps-native%2F2.9.1-4-r0%2Ftemp%2Flog.do_fetch.132923%3CBR%20%2F%3EERROR%3A%20Task%20(virtual%3Anative%3A%2FWork%2FvSLAM%2Fimx-yocto-bsp%2Fsources%2Fmeta-robot-platform%2Fimx%2Fmeta-ros%2Fmeta-ros2-humble%2Fgenerated-recipes%2Ffastrtps%2Ffastrtps_2.9.1-4.bb%3Ado_fetch)%20failed%20with%20exit%20code%20'1'%3CBR%20%2F%3EWARNING%3A%20fastrtps-2.9.1-4-r0%20do_fetch%3A%20Failed%20to%20fetch%20URL%20git%3A%2F%2Fgithub.com%2Fros2-gbp%2Ffastrtps-release%3Bbranch%3Drelease%2Frolling%2Ffastrtps%3Bprotocol%3Dhttps%2C%20attempting%20MIRRORS%20if%20available%3CBR%20%2F%3EERROR%3A%20fastrtps-2.9.1-4-r0%20do_fetch%3A%20Fetcher%20failure%3A%20Unable%20to%20find%20revision%2024c6b48d4541230c205b5d932a5830be9727cc34%20in%20branch%20release%2Frolling%2Ffastrtps%20even%20from%20upstream%3CBR%20%2F%3EERROR%3A%20fastrtps-2.9.1-4-r0%20do_fetch%3A%20Bitbake%20Fetcher%20Error%3A%20FetchError('Unable%20to%20fetch%20URL%20from%20any%20source.'%2C%20'git%3A%2F%2Fgithub.com%2Fros2-gbp%2Ffastrtps-release%3Bbranch%3Drelease%2Frolling%2Ffastrtps%3Bprotocol%3Dhttps')%3CBR%20%2F%3EERROR%3A%20Logfile%20of%20failure%20stored%20in%3A%20%2FWork%2FvSLAM%2Fimx-yocto-bsp%2Fimx8mp-ai-robot-humble%2Ftmp%2Fwork%2Farmv8a-poky-linux%2Ffastrtps%2F2.9.1-4-r0%2Ftemp%2Flog.do_fetch.176255%3CBR%20%2F%3EERROR%3A%20Task%20(%2FWork%2FvSLAM%2Fimx-yocto-bsp%2Fsources%2Fmeta-robot-platform%2Fimx%2Fmeta-ros%2Fmeta-ros2-humble%2Fgenerated-recipes%2Ffastrtps%2Ffastrtps_2.9.1-4.bb%3Ado_fetch)%20failed%20with%20exit%20code%20'1'%3CBR%20%2F%3ENOTE%3A%20Tasks%20Summary%3A%20Attempted%201123%20tasks%20of%20which%200%20didn't%20need%20to%20be%20rerun%20and%202%20failed.%3CBR%20%2F%3E%3CBR%20%2F%3ESummary%3A%202%20tasks%20failed%3A%3CBR%20%2F%3E%20%20virtual%3Anative%3A%2FWork%2FvSLAM%2Fimx-yocto-bsp%2Fsources%2Fmeta-robot-platform%2Fimx%2Fmeta-ros%2Fmeta-ros2-humble%2Fgenerated-recipes%2Ffastrtps%2Ffastrtps_2.9.1-4.bb%3Ado_fetch%3CBR%20%2F%3E%20%20%2FWork%2FvSLAM%2Fimx-yocto-bsp%2Fsources%2Fmeta-robot-platform%2Fimx%2Fmeta-ros%2Fmeta-ros2-humble%2Fgenerated-recipes%2Ffastrtps%2Ffastrtps_2.9.1-4.bb%3Ado_fetch%3CBR%20%2F%3ESummary%3A%20There%20were%2025%20WARNING%20messages.%3CBR%20%2F%3ESummary%3A%20There%20were%204%20ERROR%20messages%2C%20returning%20a%20non-zero%20exit%20code.%3C%2FPRE%3E%3C%2FBLOCKQUOTE%3E%3CBR%20%2F%3E%3CP%3E%E6%88%91%E5%9C%A8%E7%A4%BE%E5%8C%BA%E9%87%8C%E6%89%BE%E5%88%B0%E4%BA%86%E4%B8%80%E4%BA%9B%E9%81%87%E5%88%B0%E5%90%8C%E6%A0%B7%E9%97%AE%E9%A2%98%E7%9A%84%E4%BA%BA%E7%9A%84%E5%B8%96%E5%AD%90%EF%BC%8C%E4%BD%86%E9%83%BD%E6%B2%A1%E6%9C%89%E6%89%BE%E5%88%B0%E5%8F%AF%E8%A1%8C%E7%9A%84%E8%A7%A3%E5%86%B3%E6%96%B9%E6%A1%88%E3%80%82%3CBR%20%2F%3E%E6%9C%89%E4%BA%BA%E7%9F%A5%E9%81%93%E8%A6%81%E8%A7%A3%E5%86%B3%E8%BF%99%E4%B8%AA%E9%97%AE%E9%A2%98%E9%9C%80%E8%A6%81%E4%BF%AE%E6%94%B9%E6%88%96%E4%BF%AE%E5%A4%8D%E4%BB%80%E4%B9%88%E5%90%97%EF%BC%9F%3C%2FP%3E%3CP%3E%E6%88%91%E8%BF%98%E9%99%84%E4%B8%8A%E4%BA%86%E6%97%A5%E5%BF%97%E6%96%87%E4%BB%B6%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2248179%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Unable%20to%20build%20meta-robot-platform%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2248179%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F157309%22%20target%3D%22_blank%22%3E%40stevelarche%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%E8%AF%B7%E5%8F%82%E8%80%83%E6%AD%A4%E6%A1%88%E4%BE%8B%E4%BB%A5%E4%BA%86%E8%A7%A3%20openssl%20%E8%A1%A5%E4%B8%81%E9%97%AE%E9%A2%98%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%E8%87%B4%E6%95%AC%EF%BC%8C%3CBR%20%2F%3EZhiming%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2248058%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Unable%20to%20build%20meta-robot-platform%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2248058%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CBR%20%2F%3E%3CP%3EHello%3C%2FP%3E%3CP%3E%E6%88%91%E5%AE%8C%E5%85%A8%E6%8C%89%E7%85%A7%20AN14240%20%E6%96%87%E4%BB%B6%E4%B8%AD%E7%9A%84%E8%AF%B4%E6%98%8E%E8%BF%9B%E8%A1%8C%E4%BA%86%E6%93%8D%E4%BD%9C%E3%80%82%3CBR%20%2F%3E%E5%9C%A8%E6%96%87%E4%BB%B6%E5%BB%BA%E8%AE%AE%E7%9A%84%E4%B8%89%E4%B8%AA%20ROS%20%E7%89%88%E6%9C%AC%E4%B8%AD%EF%BC%8C%E6%88%91%E9%80%89%E6%8B%A9%E4%BA%86%3CSTRONG%3EROS%20Humble%3C%2FSTRONG%3E%E3%80%82%3CBR%20%2F%3E%E4%BB%A5%E4%B8%8B%E6%98%AF%E6%88%91%E6%89%A7%E8%A1%8C%E7%9A%84%E5%91%BD%E4%BB%A4%EF%BC%8C%E4%B8%8E%20AN14240%20%E4%B8%AD%E7%9A%84%E5%91%BD%E4%BB%A4%E5%AE%8C%E5%85%A8%E7%9B%B8%E5%90%8C%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CPRE%20translate%3D%22no%22%3E%24%20mkdir%20imx-yocto-bsp%3CBR%20%2F%3E%24%20cd%20imx-yocto-bsp%3CBR%20%2F%3E%24%20repo%20init%20-u%20https%3A%2F%2Fgithub.com%2Fnxp-imx%2Fimx-manifest%20-b%20imx-linux-kirkstone%20-m%20imx-5.15.71-2.2.0.xml%3CBR%20%2F%3E%24%20repo%20sync%3CBR%20%2F%3E%3CBR%20%2F%3E%24%20git%20clone%20-b%20imx-aibot-release_v3.3%20https%3A%2F%2Fgithub.com%2Fnxp-imx-support%2Fmeta-robot-platform.git%3CBR%20%2F%3E%24%20cp%20-dpR%20meta-robot-platform%20sources%3CBR%20%2F%3E%24%20ln%20-s%20sources%2Fmeta-robot-platform%2Fimx%2Fmeta-robot%2Ftools%2Fsetup-imx-robot.sh%20setup-imx-robot.sh%3CBR%20%2F%3E%3CBR%20%2F%3E%24%20DISTRO%3Dimx-robot-xwayland%20MACHINE%3Dimx8mp-ai-robot%20source%20setup-imx-robot.sh%20-r%20humble%20-b%20imx8mp-ai-robot-humble%3CBR%20%2F%3E%3CBR%20%2F%3E%24%20bitbake%20imx-robot-sdk%3C%2FPRE%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%3CDIV%3E%E6%8D%AE%E6%88%91%E5%8F%91%E7%8E%B0%EF%BC%8C%3CSTRONG%3Efastrtps%E5%B7%B2%E9%87%8D%E5%91%BD%E5%90%8D%E4%B8%BAFastDDS%3C%2FSTRONG%3E%EF%BC%8C%E7%9C%8B%E6%9D%A5Git%E7%BD%91%E5%9D%80%E5%92%8C%E5%85%B6%E4%BB%96%E7%9B%B8%E5%85%B3%E5%85%83%E5%99%A8%E4%BB%B6%E5%B7%B2%E7%BB%8F%E5%8F%91%E7%94%9F%E4%BA%86%E5%8F%98%E5%8C%96%E3%80%82%3CBR%20%2F%3E%E6%88%91%E5%B0%9D%E8%AF%95%E6%89%8B%E5%8A%A8%E4%BF%AE%E6%94%B9%E9%85%8D%E6%96%B9%EF%BC%8C%E4%BD%86%E6%98%AF%E5%9C%A8%E7%89%88%E6%9C%AC%E8%BF%87%E7%A8%8B%E4%B8%AD%E8%BF%99%E6%A0%B7%E5%81%9A%E4%BC%9A%E5%AF%BC%E8%87%B4%E5%85%B6%E4%BB%96%E5%87%A0%E4%B8%AA%E9%97%AE%E9%A2%98%E3%80%82%3C%2FDIV%3E%3CDIV%3E%E5%AF%B9%E4%BA%8E%20%3CSTRONG%3Ecracklib_2.9.8%3C%2FSTRONG%3E%EF%BC%8C%E7%89%88%E6%9C%AC%E5%A4%B1%E8%B4%A5%EF%BC%8C%E5%9B%A0%E4%B8%BA%E5%88%86%E6%94%AF%E5%90%8D%E7%A7%B0%E5%B7%B2%E4%BB%8E%20%3CSTRONG%3Emaster%3C%2FSTRONG%3E%20%E6%9B%B4%E6%94%B9%E4%B8%BA%20%3CSTRONG%3Emain%3C%2FSTRONG%3E%E3%80%82%3C%2FDIV%3E%3CDIV%3E%E9%80%82%E7%94%A8%E4%BA%8E%3CSTRONG%3EOpenSSL%203.1.0%3C%2FSTRONG%3E%E3%80%81%E5%9C%A8%20do_patch%20%E6%AD%A5%E9%AA%A4%E4%B8%AD%EF%BC%8C%E8%A1%A5%E4%B8%81%E6%97%A0%E6%B3%95%E6%89%93%E4%B8%8A%EF%BC%8C%E5%B9%B6%E4%B8%94%E6%9C%89%E5%87%A0%E4%B8%AA%20hunk%20%E5%A4%B1%E8%B4%A5%E3%80%82%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CPRE%20translate%3D%22no%22%3EERROR%3A%20openssl-3.1.0.imx-r0%20do_patch%3A%20Applying%20patch%20'0001-Enhance-cryptodev-s-engine-by-CAAM-public-key-crypto.patch'%20on%20target%20directory%20'%2FWork%2FvSLAM%2Fimx-yocto-bsp%2Fimx8mp-ai-robot-humble%2Ftmp%2Fwork%2Farmv8a-poky-linux%2Fopenssl%2F3.1.0.imx-r0%2Fopenssl-3.1.0.imx'%20CmdError('quilt%20--quiltrc%20%2FWork%2FvSLAM%2Fimx-yocto-bsp%2Fimx8mp-ai-robot-humble%2Ftmp%2Fwork%2Farmv8a-poky-linux%2Fopenssl%2F3.1.0.imx-r0%2Frecipe-sysroot-native%2Fetc%2Fquiltrc%20push'%2C%200%2C%20'stdout%3A%20Applying%20patch%200001-Enhance-cryptodev-s-engine-by-CAAM-public-key-crypto.patch%20patching%20file%20apps%2Fspeed.c%20%3CBR%20%2F%3Epatching%20file%20crypto%2Fec%2Fec_curve.c%20%3CBR%20%2F%3Epatching%20file%20crypto%2Fec%2Fec_key.c%20%3CBR%20%2F%3Epatching%20file%20crypto%2Fec%2Fec_local.h%20%3CBR%20%2F%3Epatching%20file%20crypto%2Fsm2%2Fsm2_crypt.c%20%3CBR%20%2F%3Epatching%20file%20crypto%2Fsm2%2Fsm2_sign.c%20%3CBR%20%2F%3Epatching%20file%20engines%2Fe_devcrypto.c%20%3CBR%20%2F%3EHunk%20%2310%20FAILED%20at%20747.%20%3CBR%20%2F%3Eunk%20%2311%20FAILED%20at%20774.%20%3CBR%20%2F%3EHunk%20%2312%20succeeded%20at%20808%20(offset%20-14%20lines).%3CBR%20%2F%3E...%3C%2FPRE%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3C%2FDIV%3E%3CDIV%3E%E5%8F%AF%E4%BB%A5%E7%9C%8B%E5%87%BA%EF%BC%8C%E5%AE%8C%E5%85%A8%E6%8C%89%E7%85%A7%20AN14240%20%E6%8C%87%E5%8D%97%E8%BF%9B%E8%A1%8C%E7%8E%AF%E5%A2%83%E8%AE%BE%E7%BD%AE%E4%BC%9A%E5%87%BA%E7%8E%B0%E9%97%AE%E9%A2%98%E3%80%82%3CBR%20%2F%3E%E8%AF%B7%E7%9C%8B%E4%B8%80%E7%9C%8B%E5%B9%B6%E6%8F%90%E5%87%BA%E5%BB%BA%E8%AE%AE%E3%80%82%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%E9%A1%BA%E7%A5%9D%E5%95%86%E7%A5%BA%EF%BC%81%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2247964%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Unable%20to%20build%20meta-robot-platform%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2247964%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F157309%22%20target%3D%22_blank%22%3E%40stevelarche%3C%2FA%3E%20%3CBR%20%2F%3E%3CBR%20%2F%3E%EF%BC%8C%E8%83%BD%E5%90%A6%E5%88%86%E4%BA%AB%E4%B8%80%E4%B8%8B%E6%82%A8%E7%9A%84%E5%BB%BA%E7%AD%91%E8%AE%BE%E7%BD%AE%E5%91%BD%E4%BB%A4%EF%BC%9F%3CBR%20%2F%3E%3CBR%20%2F%3E%E8%87%B4%E6%95%AC%EF%BC%8C%3CBR%20%2F%3EZhiming%3C%2FP%3E%3C%2FLINGO-BODY%3E
