UUU Enable console for u-boot-imx7dsabresd_sd.imx
edwardtyrrell
Senior Contributor I
We're after some advice on enabling the debug uart console for u-boot-imx7dsabresd_sd.imx - this initial stage of UUU. The problem is the same whether using NXP's precompiled builds with NXP's UUU scripts or our 6.12.20 build (as well as a few others)
UUU stops at:
1:3>Start Cmd:SDP: boot -f u-boot-imx7dsabresd_sd.imx
100%1:3>Okay (2.127s)
We have tried adding extra FB commands to enable the console post boot:
FB: ucmd set baudrate 115200
FB: ucmd set console ttymxc0
#FB: ucmd set silent 0
FB: ucmd set stderr serial
FB: ucmd set stdin serial
FB: ucmd set stdout serial
FB: ucmd printenv
If we can get u-boot's console going then we can see what the issues are.  We've tried bitbake u-boot-imx -c menuconfig to set the console but it fails stating "do_menuconfig is disabled, please check KCONFIG_CONFIG_ENABLE_MENUCONFIG variable"
Device imx7d (works fine using MFGTool with older 4.x kernel)
Any help would be appreciated!
Bio_TICFSL
Ok, the same happens with 6.12.3? I will tell the developers Sorry for that.
edwardtyrrell
Hi @Bio_TICFSL
Yes please do! The local.conf machine only for uboot is 'imx7s-warp'. How will we be notified if they have found a fix? This is urgent as we are trying to resolve an eMMC compatibility issue.
Kind regards.
%3CLINGO-SUB%20id%3D%22lingo-sub-2161494%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EUUU%20Enable%20console%20for%20u-boot-imx7dsabresd_sd.imx%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2161494%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%2C%3C%2FP%3E%3CP%3EWe're%20after%20some%20advice%20on%20enabling%20the%20debug%20uart%20console%20for%26nbsp%3Bu-boot-imx7dsabresd_sd.imx%20-%20this%20initial%20stage%20of%20UUU.%20The%20problem%20is%20the%20same%20whether%20using%20NXP's%20precompiled%20builds%20with%20NXP's%20UUU%20scripts%20or%20our%206.12.20%20build%20(as%20well%20as%20a%20few%20others)%3C%2FP%3E%3CP%3EUUU%20stops%20at%3A%3C%2FP%3E%3CP%3E%3CSPAN%3E1%3A3%26gt%3BStart%20Cmd%3ASDP%3A%20boot%20-f%20u-boot-imx7dsabresd_sd.imx%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%3E100%251%3A3%26gt%3BOkay%20(2.127s)%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CSPAN%3EWe%20have%20tried%20adding%20extra%20FB%20commands%20to%20enable%20the%20console%20post%20boot%3A%3C%2FSPAN%3E%3C%2FP%3E%3CP%3EFB%3A%20ucmd%20set%20baudrate%20115200%3CBR%20%2F%3EFB%3A%20ucmd%20set%20console%20ttymxc0%3CBR%20%2F%3E%23FB%3A%20ucmd%20set%20silent%200%3CBR%20%2F%3EFB%3A%20ucmd%20set%20stderr%20serial%3CBR%20%2F%3EFB%3A%20ucmd%20set%20stdin%20serial%3CBR%20%2F%3EFB%3A%20ucmd%20set%20stdout%20serial%3CBR%20%2F%3EFB%3A%20ucmd%20printenv%3C%2FP%3E%3CP%3EIf%20we%20can%20get%20u-boot's%20console%20going%20then%20we%20can%20see%20what%20the%20issues%20are.%26nbsp%3B%20We've%20tried%20bitbake%20u-boot-imx%20-c%20menuconfig%20to%20set%20the%20console%20but%20it%20fails%20stating%20%22do_menuconfig%20is%20disabled%2C%20please%20check%20KCONFIG_CONFIG_ENABLE_MENUCONFIG%20variable%22%3C%2FP%3E%3CBR%20%2F%3E%3CP%3EDevice%20imx7d%20(works%20fine%20using%20MFGTool%20with%20older%204.x%20kernel)%3C%2FP%3E%3CP%3EAny%20help%20would%20be%20appreciated!%3C%2FP%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2163758%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20UUU%20Enable%20console%20for%20u-boot-imx7dsabresd_sd.imx%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2163758%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F34846%22%20target%3D%22_blank%22%3E%40Bio_TICFSL%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%3CP%3EYes%20please%20do!%20The%20local.conf%20machine%20only%20for%20uboot%20is%20'imx7s-warp'.%20How%20will%20we%20be%20notified%20if%20they%20have%20found%20a%20fix%3F%20This%20is%20urgent%20as%20we%20are%20trying%20to%20resolve%20an%20eMMC%20compatibility%20issue.%26nbsp%3B%3C%2FP%3E%3CP%3EKind%20regards.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2163737%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20UUU%20Enable%20console%20for%20u-boot-imx7dsabresd_sd.imx%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2163737%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%2C%3C%2FP%3E%0A%3CP%3EOk%2C%20the%20same%20happens%20with%206.12.3%3F%20I%20will%20tell%20the%20developers%20Sorry%20for%20that.%3C%2FP%3E%0A%3CP%3ERegards%3C%2FP%3E%3C%2FLINGO-BODY%3E
